cranks no fire NEED HELP
Old Dec 26, 2010 | 03:18 PM
ZEXY's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: TPI 350
Transmission: Brog-warner 5 speed
Axle/Gears: Borg-Warner 9 bolt 3.45 posi
I have a Chevy 350 with 882 heads an aluminum intake and a holly carb with an msd HEI distubutor. I got the engine two weeks ago and tried to start it and got nothing from it just cranks..
Ive check the timing a 100 times and its on TDC you would think it would run like that just rough
Its got 110 compression on ever cylinder but one that one has 100
Its for sure getting fuel can see and smell it. we left the spark plugs out of the engine for a full night the next mornin put them all back in and it fired up and ran for 15 or 20 seconds then the carb ran out of fuel (on a stand no fuel pump) It does have spark on every cylinder everything says run it just dont run any ideas that i could try open to anything thanks
Old Dec 26, 2010 | 04:06 PM
lagwagon1345's Avatar
Car: 1990 camaro rs
Engine: 350 4blt tbi
Transmission: t5 manual
Re: cranks no fire NEED HELP
the same thing happened to me with a 350 i got for my camaro .. i did all the same things .. the guy i got my engine from did not inform me he had removed the timing chain and messed the cam timing up. did you check the timing on your gears?
Old Dec 26, 2010 | 10:46 PM
ZEXY's Avatar
Engine: TPI 350
ill pop the timing cover off tommarow and take a look at it thanks for the help
Old Dec 27, 2010 | 12:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by ZEXY
it just cranks..........
So what does it do if you have enough fuel ?
Old Dec 27, 2010 | 02:16 PM
ZEXY's Avatar
Engine: TPI 350
I got a fuel pump i found layin around and wired it up and put one end in the can and the other on the carb and used it just incase it fired up and it still just cranks and nothin after that it wont sputter or pop or anything
Kinda frustrating lol
Old Dec 27, 2010 | 02:18 PM
ZEXY's Avatar
Engine: TPI 350
I got the timing cover off this mornin and the marks were right were there suppose to be
Another thing is i just found out this was a fuel injected vortec engine would the blocks be different from the heads
Old Dec 27, 2010 | 10:41 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I got the timing cover off this mornin and the marks were right were there suppose to be...
Cam dot at 6:00 and crank dot at 12:00?
Old Dec 28, 2010 | 12:51 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What do you know about engine.
Was it a runner before you got it?
Are the valves set right?
Old Dec 28, 2010 | 01:22 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Pull dizzy check the gear. Roll pin could be messed up just had that happin with a msd. Good luck
Old Dec 29, 2010 | 01:18 PM
redcamaro1988's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
I am having a no fire issue. It ran fine one day then it wouldnt fire off starting fluid. Also it had been idleing rough. Any help would be nice.
Old Dec 29, 2010 | 07:15 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Probably the wrong plugs for a carb. They're probably shot by now. Use plugs that can be gapped at .035" to trouble shoot.
Old Jan 2, 2011 | 11:34 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
You say this was supposed to be a Vortec?? If so 882 heads are not supposed to be there. From what I have read, they are some of the crappiest heads you can have. I read about them, because I have a set on my 68 327 block.
Old Jan 11, 2011 | 06:42 PM
ZEXY's Avatar
Engine: TPI 350
sorry its been so long i appriceate the help.
Ok so hears what i have found out about the engine it came out of a 94 chevy pickup it was a vortec engine in that truck the guy said that it just stopped running one day so he thought the fuel injection went out. turns out it was just the computer but he had torn it down to a short block
he stuck some 882 heads and a edelbrock torker intake he had layin around and a holley carb played with it for a week and sent to me to see if i could do somthing with it and its got me stumped. Ive done the timing a hundred times making sure i didnt miss somthing and its fired up once ran for about 30 seconds and then the carb ran out of fuel now nothing.
I know 882 heads may not be the best for performance but were just trying to make it run thats all. the cam was at 6 and the crank at 12 so nothin there it has compression in all the cylinders about 110 except for cylinder 3 its at 85. Im 100% for sure the timing is at TDC and nothing from it. And about the distubutor i have had two HEIs in it one came from my running blazer just to see if hes was bad and still nothing went right back in the blazer and it still runs so ..... LOST
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
skinny z
Oct 5, 2015 06:23 PM
