spark plugs?..delco still ok?
Old Jan 1, 2011 | 08:17 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, are ac delco plugs still good enough for a 350 with rough idle cam(no specs) and a 4 bbl carb?...anything out there better or worth trying?...thanks.
Old Jan 1, 2011 | 08:32 PM
travis_henry's Avatar
Car: stock car
Engine: 350 Chevy
Transmission: 1.76 powerglide
Axle/Gears: 3.73s
Re: spark plugs?..delco still ok?
everything i ran from crazy cam to heads and carb gas, E85, Alky autolite 26 plugs worked the best for me.
Old Jan 1, 2011 | 08:56 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Is the ignition system basically factory?
If so, then the R45 delco's work fine.
GM's run good with Delco.
Old Jan 1, 2011 | 09:02 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
NGK has some iridiums that I want to try but to date I have always run the delco's and had no problems.
Old Jan 1, 2011 | 09:10 PM
ville_valo_05's Avatar
Car: 1985 Trans Am Limited Edition
Engine: 305 tpi
Transmission: 700r w/ stage 2 shift kit
i've heard good things about the ac delco rapidfire plugs
Old Jan 2, 2011 | 08:24 AM
mooch1's Avatar
Transmission: T5 WC
yes, it is the HEI distributor with accel cap rotor and coil and plug wires..i figured since i had a different coil and wires that i neede to upgrade the plugs too...since i have headers, i thought a shorter plug as well as more efficient plug was needed...
Old Jan 2, 2011 | 05:55 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I recently picked up some AC Delco plugs. Havent put them in yet because of snow and not having the right tools but I have heard great things about them. I think the part number is R43TS. Got new plugs because my car is running like they have never been replaced.
Old Jan 2, 2011 | 06:38 PM
mooch1's Avatar
Transmission: T5 WC
so i guess, it seems even with a mild 350..delco plugs are the way to go..
Old Jan 4, 2011 | 03:38 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
always been a big fan of delco's and ngk's for my GMs
Old Jan 5, 2011 | 02:36 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I just switched over to AC Delco in the IROC. As you can see from my sig, I run Trick Flow Twisted Wedge heads and thought that the NGK Iridiums might be better. Also wanted a long lasting plug since replacing them is such a chore with the large primary headers. The thing is though that the AC Delco platinums have a much larger electrode than the NGK Iridiums. The AC Platinums also run 100K in OE applications so durability isn't an issue.
I want the largest flame front possible for complete combustion and I think the larger electrode of the ACs will produce a fatter spark, thus helping to generate a larger flame front.
Old Jan 11, 2011 | 02:05 PM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
I have a basically stock 1989 Camaro Rs. with a 305 tbi. I want to keep it as stock as possible. I want to use ac delco. Should i purchase the standard, or platinum plug?
Old Jan 11, 2011 | 02:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Big shoutout for Autolites
They did something new, in many different engines, I have seen them go in and be flawless. Where AC or NGK couldn't provide the same experience.
Old Jan 11, 2011 | 02:23 PM
Engine: 305 tpi
anyone used the delco rapidfires yet?
Old Jan 11, 2011 | 06:59 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I have in my Stock 83Z. No problems at all.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
