How can I increase power?
Old Dec 28, 2010 | 01:53 AM
roten.ben's Avatar
Hey guys, I got a '84 Z28 with the LG4 5.0. So far I put a brand new flowmaster exhaust there and an edelbrock air cleaner. I just put a rebuilt quadrajet carb on there because my old one was junk, so I don't want to buy another carb. What else can I do to give it a little extra power? Thanks guys
Old Dec 28, 2010 | 02:32 AM
SoCo80p's Avatar
Re: How can I increase power?
Do a full tuneup if you haven't already (new plugs, wires, rotor, cap,..etc) also change all the fluids on the car (oil, trans, radiator, brakes, PS,..etc) You'd be amazed many times the performance gains just by making sure it's running right.
Old Dec 28, 2010 | 08:22 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Nitrous.
Old Dec 28, 2010 | 08:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Headers, cam, heads
Old Dec 28, 2010 | 08:44 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
50 more cubes
Old Dec 28, 2010 | 09:00 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
i have an HEI Ignition/distr. for that engine, im parting out an 84 T/A, view my posts to see thread.
Old Dec 28, 2010 | 09:12 AM
The car in question came with HEI.
In any case, changing the ignition system won't affect its power output.
Go here for common-sense, unbiased, reality-based advice.
https://www.thirdgen.org/forums/carb...tions-lg4.html
Old Dec 28, 2010 | 09:14 AM
Let me re-phrase, its an Accel HEI aftermarket unit and yes it wont Increase power, however it Will make the engine use the power it has more efficiently.
Old Dec 28, 2010 | 09:17 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really.
Old Dec 28, 2010 | 09:20 AM
Originally Posted by Apeiron
Not really.
I'd really enjoy seeing an explanation on that one.
Old Dec 28, 2010 | 09:21 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Originally Posted by Grumbles
50 more cubes
And a tune up wounld help. Too
Old Dec 28, 2010 | 09:24 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd need an explanation why you think it "uses power more efficiently" first.
Old Dec 28, 2010 | 09:30 AM
Stock HEI loses voltage after 4500-5000 RPMs, Accel's/MSD's etc provide voltage to 6500Rpm's therefore allowing the lost power over 4500-5000 RPM's to be extracted by using the high voltage aftermarket HEI units.
Old Dec 28, 2010 | 09:36 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The original HEI units did, the later ones not so much. More voltage doesn't equate to more power, though. As long as the plug still lights the mix, which isn't difficult in a low-speed, low-compression, low-output engine that makes peak HP at about 4000 RPM.
Old Dec 28, 2010 | 09:39 AM
ok i see your point but your missing mine, i still havent said it INCREASES max HP, i merely said it will utilize the power available after a certain RPM that a stock coil cannot attain.
Btw: OP, sorry for the hi-jack, this is my last post.
Old Dec 28, 2010 | 03:35 PM
roten.ben's Avatar
It's alright guys, thanks for all the responses! When it gets a little warmer I think I might replace all the fluids and get a tune up and what not. Maybe I'll stick in a new cam too. Thanks guys
Old Dec 28, 2010 | 05:13 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
If the engine's internals are stock it isn't worthwhile to shift after 5000 anyway... heck, my old LG4 ran out of power around 4700-4800
customblackbird
Aug 15, 2021 10:16 PM
bamaboy0323
Sep 3, 2015 06:07 AM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
forstral
Aug 19, 2015 03:20 PM
