Distributor problems
Old Jan 1, 2011 | 01:47 PM
tjl894762's Avatar
Car: 1989 IROC-Z
Transmission: 700-r4
Axle/Gears: 2.77 posi
Okay so I'm having some problems with my 350 tpi. I just changed the head gaskets, and now that im putting it back together and trying to time it something is mystifying me. If i plug the four prong plug on my distirbutor back in. The one you have to unplug to set initial timing, the car dies insantly. It'll then crank for days untill you unplug it again then it starts right back up. This all has me puzzled. I've done some investigating on the car and found that a previous owner installed an ACCEL stand alone injection system. And that there isn't even a stock computer in the car. The distibutor is also not the one that orginially came in the car. It's a coil on-top HEI like the ones in 85 z's. Not only this but its locked out. So this as well has me confused. I just replaced the injectors with 22lb stock units. And i have full 3" exhaust. I am wondering what any of you suggest i do. I am trying to spend as little as possible for now as I just dumped quite a bit into the injectors and head gaskets. So where should i put my timing. As well as what you all think about the plug issue? Any response gets me farther then where I am now. Please and Thank you. Tyler
Old Jan 1, 2011 | 05:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Distributor problems
Not the one you unplug to set timing on a stock TPI system
Spark timing connector is a single wire unit same as one shown below ( in a Vette )
Aftermarket harness should have same provision
Old Jan 1, 2011 | 05:52 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I would start by downloading and reading the instructions for the Accel ECM unit you have.
The distibutor is a coil on-top HEI . Not only this but its locked out.
Maybe the Accel ECM can run engine without ECM control of spark advance ? ( mech advance only )
Can you talk to PO?
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
