Confirmed gas leaking, need to figure out where from. How to? :(
Old Jan 18, 2011 | 09:40 AM
84CAMARO28inFL's Avatar
Its confirmed, gas is leaking. i know this from adding 4 gallons and seeing the gauge move up, then reading on E now.. and brown discoloration coming from the back where the gas tank is, along with a strong smell of gas i smell more after the car ran, 84 Camaro, carburated, 2.8L V6.
How do it will if its the gas TANK or the LINE? Since changing the line would be easier and if its the connection thats leaking thats fine, but the tank, i found one on EBay. I forget how much it costs to change the tank!
Old Jan 18, 2011 | 09:47 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Confirmed gas leaking, need to figure out where from. How to? :(
It sounds like you should probably pull your tank to inspect it and see exactly what's going on there.
Old Jan 18, 2011 | 09:49 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i would just park it and wait a while, then go back and check. you may find a puddle or even see the drip whether its steady or intermittent. i had some bad fuel lines in my 84 a while ago and ended up having to get it replaced.
if it IS the tank, look into the 4th gen tanks, they are made out of plastic i believe = help you shed some weight and they are about the same size.
for changing the tank i believe you have to drop the rear in order to get to it, i'm sure there are write up seeign how people change fuel pumps fairly often.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
wayshegoes
Aug 17, 2015 12:00 PM
