Tore off my throttle body Help Quick!
Old Jan 23, 2011 | 04:18 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Ok I got a little whats the word??... adventrous? And decided to tear off my throttle body for no apparent reason, anyhow I pulled off whatever this is http://www.facebook.com/#!/photo.php...00001242637904
and I have the rest of the TB soaking in some cleaner, but do I also throw in what I pictured above? is that the IAC motor? Yes or no do I put in the cleaner? If not in bucket, can/do I clean it manually?
And my gaskets appear to be fine, but just incase... how much are new gaskets for the throttle body and whats the part #? How much is a gasket kit (along with part #) if I wanted to tear off the plenum and runners also?
If im forced to go to shucks and get gaskets, should I pick up anything else there? Should I get the TPS (i belive thats what it is *black triangle almost, has 3 connectors inside it) tested? Is there anything I should be aware of? (btw I took pics during the removal of everything)
oh yah, also what are the 9? screws called that remove the pictured item? Thanks!
Old Jan 23, 2011 | 05:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Tore off my throttle body Help Quick!
Originally Posted by iroc stangs
whatever this is. is that the IAC motor?
Not everyone has Myface
Do not soak anything that has a elec connection or you will be buying new parts
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
