700R4 TV Cable Question
Hope this fits into the area of this forum but would someone please confirm my thought. If I were to transplant a 5.7 TPI (MAP) and a 700R4 into a non third gen car, could I not just use (a new) stock cable that fit the original vehicle? In other words, aren't the TV cables all the same length and simply go from the tranny to the bracket on the plenum? Am I missing something?
thanks...
thanks...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 TV Cable Question
The TV cables for a particular type of throttle body are all the same.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Possibly any parts store should have them.
Thing with a cable transplant, say you take it off a carbed car and go to install it on a TPI you will see its not going to reach around.
Car: 87 Camaro
Engine: 305 LG4 (H)
Make sure the cable sits in the trans flush before tightening the nut. I had that issue the cable didn't sit flat and fluid leaked out when the car sat overnight.
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
i work at a gm dealer,and the cable is only about 30 bucks,i just bought one 2 weeks ago,even if you paid full list i bet it wont be much more,i am a firm believer in quality gm part for something so important-dont wanna f### up a tranny to save 10 bucks!
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
And even though the parts are more and more comming from china I still liike to buy Delco when I can. Just today I am putting pulse wipers in my mom's S10 and needed a wiper switch so I got a Delco (this one was made in Mexico) over a autozone Dontlast.
Thanks everyone for the input...My research at the local GM dealer revealed Part # 10163879 fits 89-91 Camaro, Corvette and Firebird (around $52.00) and confirmed my suspicion (and Aperion's quote) that the cable for the 700R4/5.7 TPI combo is pretty much, if not, exactly the same.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Its also the same cable on the 5.0 TPI.
As I mentioned, its pretty much what fuel system the cable needs to go around and connect to.
