Starts but doesnt stay running
Old Jan 26, 2011 | 10:27 PM
Jonnotjohn's Avatar
91' z28 camaro starts up but wont stay running without feeding it gas, just started today. tried some sea foam which keeps it running but very sluggish just above stalling point so that when i use the breaks it still dies on me. i know its the fuel system but im wondering if theres a specific part that can cause this before i start dismantling stuff and i really dont have the money to just replace stuff one by one.. any suggestions would be awesome thanks guys
Old Jan 26, 2011 | 10:40 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Starts but doesnt stay running
Carb or FI?
Old Jan 26, 2011 | 11:04 PM
Jonnotjohn's Avatar
fuel injection TPI
Old Jan 26, 2011 | 11:20 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
You can check the usual like fuel psi, leaks in the regulator diaphragm.
Throttle Position sensor
Dirty Idle Air Control Motor
Fouled spark plugs
Faulty EGR
Vacuum leaks
Old Jan 27, 2011 | 08:42 AM
mwinburn's Avatar
Car: 1989 Formula Firebird
Engine: 5.0L 305 TPI
Transmission: 5 Speed
I'd do a check to see if your fuel pump is working. When you turn the key to on you should hear a buzzing near the rear of the car. thats the fuel pump getting the system up to pressure if you don't hear that your pump may be bad.
Old Jan 27, 2011 | 12:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can check fuel pressure driver side fuel rail should have a schraeder valve (like a tire stem) on it - a $10 fuel guage will go right on it. I'd throw another $10 at a new fuel filter as well - never hurts to have a new fuel filter. Then, as mentioned, TPS, IAC, EGR, vacuum leaks, plugs, etc.
Old Jan 27, 2011 | 04:54 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Check for codes, ohm your fuel injectors too.
Ghettobird52
Jul 5, 2024 11:18 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Sherpajames
Aug 7, 2015 06:56 PM
