please if u know something reply
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
1992 trans am 305 tpi
new intake with runners...ac delete and air pump delete....the car starts but wont stay on wat could be the problem...is it a vaccuum leak?
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: please if u know something reply
I assume it ran fine before the work? I would look into the timing. Have you checked the timing to make sure it is correct? Easy to get the distributor back in the wrong location. Bring number one up to TDC and check the rotor location. Re-stab the distributor if necessary and try to start it. Don't forget to disconnect the computer when you time it once you get it running that is. The other obvious things, wires and vacuum lines all hooked up? Injectors all connected, etc.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Look over EVERYTHING that you did. Leave a connector unplugged???
And FYI, "What" is spelled with a "H" and there is only one "C" in "Vacuum". But all got the two "Us"correct. Kudos on that!!!
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Will it run above idle? Double check everything mentioned above throughly from one end to the other and follow basic tune up procedures and settings for the TPI system. It won't hurt to check the fuel pressure either.
Car: 89 RS
Engine: 2.8
What really matters is whether or not we help this guy get his car running.
Kevin
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I'm still learning to type! Still use just my index fingers and at times my thumbs but I don't have to look at the keyboard as much.
And it does not hurt to help a person elsewhere a little bit along the way.
Next lesson will be with the difference between "your" and "you're", watch for it.
("UR" is not a word and looks retarded when used as one)
Car: 89 RS
Engine: 2.8
So back to the question in the thread. Have you made progress on getting your car running transamws6? Mad Iroc, I doubt u will stop people from using shorthand in these threads cause its done to get the message out quicker and to take up less space. U will see this a lot in texting. People r not so worried about spelling on here. They jus want to offer advice. No offense but if spelling bothers u, u will b bothered a lot.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I have no doubts I will not get people to stop using what they think is shorthand. Maybe though people will show they have some intelligence. "Ne one" is retarded, not "shorthand". You're here communicating with others on the web in a forum, not texting with your buddies.
Car: 89 RS
Engine: 2.8
Did you get it running yet? All spelling lessons aside. I just hope you get some good advice on getting your car going.
I thought there would a reply by now.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
If your distibutor is in correctly and timing set correctly then you should look for vacume leaks. Hopefully your intake base is not leaking. Could possibly be a fuel injector gone bad too. Check with a multimeter.
