roller rockers
Old Feb 2, 2011 | 07:51 PM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
roller rockers
I didnt see any posts about this. Would putting in 1.6 ratio roller rockers on a stock tpi 350 free any power that I would notice. I am just looking to gain some hp and tq . I dont want to do anything that will shorten the life of my engine or modify it much from stock. Would I be better off spend the $250 on something else.
Old Feb 2, 2011 | 09:05 PM
InjectorsPlus's Avatar
Former Sponsor
Re: roller rockers
I think they're worth about 15 hP tops. Not a bad payback for the money.
Old Feb 3, 2011 | 12:12 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: roller rockers
250$ on roller rockers? use summit's brand, i used their on another build some years ago and they were $170 shipped..
Old Feb 3, 2011 | 02:11 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: roller rockers
1.6s should be common place on a abc valve lift is very important.
BTW I do have a set of Lt4 rockers in the classifieds.
Old Feb 3, 2011 | 11:11 AM
Former Sponsor
Re: roller rockers
doesn't just change the lift, it changes the ramp too, so the power comes on a bit faster.
Old Feb 3, 2011 | 11:23 AM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
Re: roller rockers
be sure and get the steel ones not the aluminum ones unless your car is strictly a race car. ( i hear they break after 10k miles or so ) i used comp cams pro magnum 1.6's and i felt a difference especially in the higher rpms. and they were around 190 bucks.
Old Feb 3, 2011 | 11:29 AM
Former Sponsor
Re: roller rockers
The trend is away from Aluminum to Chro-mo they are stronger, lighter, and more rigid.
Old Feb 3, 2011 | 11:45 AM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: roller rockers
How much and what ratio. This has been really good info are the lt4 aluminun could you sent some info about them thank you
Old Feb 3, 2011 | 11:55 AM
Car: '88 Trans Am
Engine: 5.7L TPI
Re: roller rockers
That change is small..... the power is more noticable in the upper rpms.
be sure and get the steel ones not the aluminum ones unless your car is strictly a race car. ( i hear they break after 10k miles or so).
If aluminum roller rockers break after 10,000 miles EVERY 96 corvette w/6spd along with the Lt4 SS and Birds would be on the side of the road! Aluminum roller rockers have been used for ever its just the steel rockers have less deflection at high rpm barely noticable unless your motor runs above 6000 rpm for any amount of time.
Old Feb 3, 2011 | 12:45 PM
Former Sponsor
Re: roller rockers
Agreed!
Old Feb 3, 2011 | 03:59 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: roller rockers
So aluminum will be ok. Upper rpms is where I really want to get the power. Love the launch off the line. I hate the way the power levels out over 3k rpms. Whats the ratio on the factory rockers. would I need to program the computer to run these
Old Feb 3, 2011 | 04:11 PM
Axle/Gears: 3:27
Re: roller rockers
stock is 1.5 and no you dont need a tune for 1.6 roller rockers.
Old Feb 3, 2011 | 04:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: roller rockers
Another option is Roller-Tip rockers. They come in 1.6:1 ratios. You get the benefit of the roller tip not grinding away at the top of the valve (or the valve grinding away at the rocker), the increased ratio, and less cash spent - they run about $100 and up a set, some brand names get as expensive as full roller rockers, but I've used the Summit brand ($100) with no issues at all. Not sure I'd run them on a monster race motor, but for a stock replacement they are great and allows you to see the difference without a large cash layout.
http://www.summitracing.com/search/P...?Ns=Rank%7cAsc
Old Feb 3, 2011 | 04:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd say if you didn't know which were installed in the engine, and you drove it 10 times, 5 times with each rocker, at best you'd be able to tell correctly which ones were in the engine maybe 50% of the time.
It just doesn't make that much difference.
Old Feb 3, 2011 | 04:50 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: roller rockers
I see in summit they have "Summit" roller rockers for $169 that is a better price then the $230 for the Harland Sharp
Old Feb 4, 2011 | 08:30 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: roller rockers
His '91 is a speed density car. The VE will be off with the slightly higher lift, and the ever so slightly earlier/later open/closing points.
Also, one can assume the AFR under PE mode will be slightly off.
So suggesting that he doesn't need to tune is wrong.
-- Joe
Old Feb 4, 2011 | 08:35 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: roller rockers
I used the summit a couple years ago and they seemed ok. I've used a lot of different brands over the years, and the only ones I had bearing problems with were the steel CAT ones. But they did replace the defective rockers under the lifetime warranty.
I'm using procomp 1.6's on my 412 right now.
Oddly enough, all the cheap rockers seem to be fine, it's the polylocks that come with cheap rockers that will get you when you are not looking. I've had cheap polylocks back off before, and when it does it's a nightmare.
-- Joe
Old Feb 4, 2011 | 08:37 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: roller rockers
-- Joe
so where would i get it tuned at and whats a good price for a tune?
Old Feb 4, 2011 | 08:39 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: roller rockers
-- Joe
Do the " Summit " brand have the polylocks? If they do do I just call Summit and ask for a set without polylocks?
Old Feb 4, 2011 | 10:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: roller rockers
It's a TPI ;
changing the rockers ratio is not going to change the fact that the intake can't breath over 4500 rpm
Old Feb 4, 2011 | 10:50 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: roller rockers
Originally Posted by vetteoz
It's a TPI ;
yup. they can only flow so much. now they might pick up a little more power earlier on. but peak flow #'s are peak flow #'s.
Aluminum ones break. plain and simple. see them on youtube all the time. the factory rocker arms on corvettes are different. OEM stuff is better than aftermarket especially summit brand, proform, etc. Harland sharp is good and I heard good things about Scorpion's. But I run the comp cams steel magnum rockers on my dodge. I have stockers ont eh camaro still til I upgrade heads.
Old Feb 4, 2011 | 11:52 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: roller rockers
Locally, you would have to ask around. $250-500 for an initial tune is about average. You could always buy the equipment and tune yourself.
-- Joe
Old Feb 5, 2011 | 01:02 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: roller rockers
Are there any 1.6 roller rockers that will fit on a 87 L98 with center bolt Corvette magnesium valve covers with the internal drip tabs?
Old Feb 5, 2011 | 02:16 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: roller rockers
There are narrow body styles that fit but you have to cut the drip tabs off
Old Feb 5, 2011 | 03:17 PM
85 ZXX's Avatar
Re: roller rockers
Well, I guess I will keep the drip tabs and pass on the 1.6. Thanks though.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
