quadrajet carb, two fuel outlets?
Old Feb 2, 2011 | 09:45 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
Excuse my simpleton question but i cant seem to find the information im looking for online. I recently switched to a carb setup, i have a quadrajet 4 barrel, ive got one fuel inlet at the front of the carb, but there is also a fuel inlet/outlet at the rear of the carb.
So is it a extra inlet to plumb sum more gas like the edelbrock or holley carbs, or is it a return? thanks, Joshua
Old Feb 2, 2011 | 09:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: quadrajet carb, two fuel outlets?
There is no fuel fitting at the back of the carb.
Old Feb 2, 2011 | 10:17 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If it's the fitting/threaded hole on the back of the throttle plate, that probably for the PCV valve hose.
Old Feb 2, 2011 | 10:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I think the fitting you're referring to a the rear of the carb is for the power brake booster line.
Old Feb 2, 2011 | 10:49 PM
should i plug it if its just for pcv, since i already have a vaccuum line for the pcv connection. The brake booster is off of my intake manifold. or should i just leave it open? i just went from not sure to puzzled? i will take a picture of it tomorrow. thanks Joshua
Old Feb 2, 2011 | 10:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
If you're not going to connect anything to it, plug it. It'll be a huge vacuum leak if you don't.
Old Feb 2, 2011 | 10:57 PM
heres what im talking about, ive looked at pictures and see a hose running from it but the picture executes before i can see where it goes. THnkas. Josh
Old Feb 2, 2011 | 11:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Power brake booster.
Old Feb 3, 2011 | 04:42 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
That is a flare fitting and will be hard to plug. Best to remove the flare adapter from the base and install a 1/4" pipe plug in the hole that's left.
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
