Please help!! check engine light.
Car: 1989 Trans Am GTA
Engine: L98 350 TPI
Transmission: 700r4 B&M shift kit
Axle/Gears: stock, G4 posi
My check engine light turns on and off multiple times throughout the week. I've used the code reader at schucks but it reads no codes? even when the light is on. it has a slight hesitation, and at cruising speed it kinda surges. Any ideas??
Engine: L98 350 TPI
Re: Please help!! check engine light.
and then i would count how many times the light flashes if at all?
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Should flash once ,then pause ,then flas two times. That is normal, that is code12. Also your secondary fan should come on.
