another jerking problem
Car: 87 Camaro LT
Engine: 2.8L
Transmission: Manual
ok, i have a 87 camaro lt and ever since i got it the thing seemed to have a sort of hesitation while accelerating. recently this problem has become full out jerking (at least i think it is the same problem) i automatically assumed it needed a tune up and replaced all spark plugs wires distributor and although this made the car run better, still didn't fix the initial problem. Now this only seems to become worse once the car is wamred up and i'm not sure if it's a coincidence or not but it also seems to do it while going down hill. I then thought it may be the fuel filter so i replaced that and once again, made the car run better, but ddn't fix the problem. the biggest problem is that my service engine light won't come on and give me any codes so that i can troubleshoot. PLEASE HELP! any suggestions would be awesome! (and could possibly cure my headache, haha)
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: another jerking problem
Might need a new ignition module inside the distributor - most parts store chains will test them for free but I never bothered I just replaced as they aren't that expensive.
Car: 87 Camaro LT
Engine: 2.8L
Another symptom of this problem is that i seem to be getting air in the fuel rail. If i clear out the air, the problem goes away, however, i have to let out the air everytime i want to drive the car. What are some possible ways i could be getting air into the fuel rail?
Car: 91 Camaro RS
I don't know about the air in the fue rail, but your other symptoms sound like a problem I had with mine. Do you get less jerking if you milk the clutch (if you have a manual)? After replacing everything, I finally broke down and put a new fuel pump in and cured the problem I had for over a year.
Car: 87 Camaro LT
Engine: 2.8L
it does seem to help when i push in the clutch. but only sometmes, sometimes i push in the clutc and it stalls the car...
i do have lots of fuel pressure, which is makin me start to think it might be something to do with ignition. distributor maybe? arg. i wish i could figure this one out!
i do have lots of fuel pressure, which is makin me start to think it might be something to do with ignition. distributor maybe? arg. i wish i could figure this one out! Trending Topics
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
spray some water around the bottom of your injectors and listen to hear it sucking in. maybe you need a new o ring.
happens on my car all the time
good luck
good luck
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
This could also be a leak in the rubber hose between the pump and sending unit inside the tank, causing the fuel to cavitate. See if the problem is better with a full tank of gas. If so, it's the hose in the tank.
