Modern engine oil
Old Feb 5, 2011 | 01:12 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Modern engine oil
Is it OK to use the folowing oil in my car:
Castrol Edge Formula RS SAE 0W40 SM/CF
ACEA A3/B3/A3/B4 C2 C3
1988 Firebird Formula 350 5,7L TPI
Thanks.
Old Feb 5, 2011 | 01:55 PM
Re: Modern engine oil
Yes. Should do the job.
Old Feb 5, 2011 | 03:34 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
You should have a roller camshaft and if so that oils would be great.
Old Feb 6, 2011 | 02:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its a small block Chevy... they aren't picky lol.
Old Feb 9, 2011 | 05:13 AM
http://www.zddplus.com/
How about this..?
Old Feb 9, 2011 | 06:49 PM
Air_Adam's Avatar
If your engine is original to the car, then it came equipped with a roller cam. The additive isn't necessary, and is of no benefit, with a roller cam.
Old Feb 9, 2011 | 07:35 PM
Engine: 355
We use Brad Penn Oil, At $4.95 qt. it is cheap insurance. We also try to use roller cams when ever we can. http://www.performancespecialtiesinc...rformance-oil/
Old Feb 10, 2011 | 09:38 AM
Old Feb 10, 2011 | 09:39 AM
Thanks !!
Old Feb 10, 2011 | 10:01 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ZDDP is a popular addtive for rodders but you can also get "break in" oil, its a term used to get around the loops hole of them making them take the good stuff out of oil.
Old Feb 10, 2011 | 10:24 AM
whiteboycv67's Avatar
Car: 90 Firebid
Engine: 3.1
Axle/Gears: 10 bolt posi w/4.11s
just dont use penzoil or quaker state lol its crap
Old Feb 10, 2011 | 10:29 AM
Why..??
Old Feb 10, 2011 | 11:02 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
not sure what he is refering too but Quaker State has had a bad rep for a long while, We learned that in tech school to never use it in a small engine [ small engines class, motorcycles, boats, tractors] As folks would bring in stuff for repair and the ones that had a inch of thick goop on the bottom of the pan had owners that used QS.
Old Feb 10, 2011 | 11:45 AM
I've used Quackerstate Outboard in my Suzuki two stroke, years ago, never any problems, and I have used Penzoil GP 20W50 in my Firebird without problems too...???
Old Feb 10, 2011 | 02:27 PM
Air_Adam's Avatar
That oil is fine, and you don't need any additives, since you have a roller cam. Its similar to what I've used in my '97 Camaro and i never had any problems with it.
Old Feb 10, 2011 | 04:12 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I've used pennzoil all my life. Never a single problem.
Old Feb 10, 2011 | 04:56 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
To the OP: What made you pick 0W-40 as opposed to the factory recommended weights, or any other for that matter??
Old Feb 10, 2011 | 05:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I use 5W-40 in mine. The tight clearances in the bottom end need a thinner winter weight oil, while the lifters need 40 weight at temperature, or they bleed down and tick. The 0W will be a bit thinner at lower temps, and circulate better when the engine is cold. The only thing Ive wondered about the 0W oils is how well they hold their viscosity as the oil ages. That oil probably has a lot of VIs in it to give it that flatter viscosity curve.
Old Feb 10, 2011 | 05:19 PM
Car: 88 Camaro SC
Engine: SFI'd 350
It can help with the rocker arms and pushrods, which have high loads and are sliding contacts like a flat tappet. With a factory cam and springs, its probably not as critical as an aftermarket setup would be with higher spring pressures.
Old Feb 10, 2011 | 05:25 PM
thewizard's Avatar
I understand the purpose behind your situation of course, but I was taking a guess from the OPs comments that he has a near stock setup that woudn't dictate any change from normal unless he observed changes.
This is what I always think of when I see the large spread in cold and warm oil ratings. I've heard many a' stories about oils like this not having the integrity of a 5W-30 for example.
Old Feb 10, 2011 | 06:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Plus its not gonna hurt anything it can only help, so there is no down side to it.
Old Feb 10, 2011 | 08:51 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
Originally Posted by Gumby
not sure what he is referring too but Quaker State has had a bad rep for a long while, We learned that in tech school to never use it in a small engine [ small engines class, motorcycles, boats, tractors] As folks would bring in stuff for repair and the ones that had a inch of thick goop on the bottom of the pan had owners that used QS.
Oil has changed a lot in recent years. Visit BITOG for everything you ever wanted to know about oil and more.
CG
Old Feb 11, 2011 | 09:17 AM
My engine is stock indeed.
I use Castrol, because I've been using it since I was a kid in everything with an engine.
The Castrol RS Power1 0W40 is the latest, and best oil Castrol has ever made in Europe, and since it is 100% synthetic, there are no VI's in it at all.
I choose 0W40 because it comes close to the recommended 0W30, 0W40 being slightly thicker when at operating temps, which wouldn't hurt, since the car has done about 100.000 mls.
Old Feb 11, 2011 | 08:36 PM
thewizard's Avatar
Sounds like a great choice then.
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
