Accel Corrected HEI Cap
Old Feb 12, 2011 | 06:51 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Car runs good.
Attached Thumbnails Accel Corrected HEI Cap-001.jpg   Accel Corrected HEI Cap-002.jpg   Accel Corrected HEI Cap-003.jpg
Old Feb 12, 2011 | 09:29 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: Accel Corrected HEI Cap
What it's in.
Attached Thumbnails Accel Corrected HEI Cap-313.jpg   Accel Corrected HEI Cap-315.jpg   Accel Corrected HEI Cap-314.jpg
Old Feb 13, 2011 | 12:13 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Cool looking car. Like the cap, I might try one. David Vizard spoke of it in a book of his I have.
Old Apr 5, 2011 | 08:45 PM
83firechicken's Avatar
Car: 1983 firebird
Engine: 427 v8
Axle/Gears: 3.42 posi
defently getting that its so cool
Old Apr 5, 2011 | 08:51 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I really wish they made these for regular MSD distributors. They look so much cleaner.
Old Apr 5, 2011 | 10:24 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I'm going to chime in as the only guy in the world not loving the "corrected" cap.All I can think of is the poor bastard a couple of years down the road that puts a new cap and rotor on,and spends an hour trying to figure out why his car is running like junk.
Old Apr 6, 2011 | 06:06 AM
Car: 1983 firebird
Engine: 427 v8
you know thats what i thought about that 4-7 swap cams if you ever sold the car and someone tried wire it up as a regular small block they would have one awful time figuring it out , as most people would think to adjust timing and that kinda thing not realizing it's actually a wrong plug wire order
Old Apr 6, 2011 | 08:10 AM
built91Z28's Avatar
While these things could happen, I am building my car for me. Not someone who may buy it down the road. Even if you do sell it down the road they can look at how it was before hand and put it back the same. Thats also why its important to get as much info from the PO and if he says the motor is built with all unknown parts, then its best to walk away.
Old Apr 6, 2011 | 06:59 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
that is sexy. i have been looking at getting one for a while. but have been low on funds lately.
Old Apr 6, 2011 | 09:15 PM
Vader's Avatar
The only potential problem with those is the insulation breakdown in the cap. It happens to almost every 4.3L Chevy V-6 eventually, and almost every LT1 eventually. The insulation system is the SAME, and Accel has not learned to get it right on replacement caps for 4.3L V-6s to this day. That would be a point of concern eventually, so the next time you develop a miss don't think it isn't the cap because it only has 5,000 miles on it. There are hundreds of documented cases of high-end aftermarket caps doing this in 5-10K and Delco/Delphi caps solving the problem for another 100K miles.
Old Apr 6, 2011 | 09:28 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
I might have learned that the hard way. It started running rough and I wasn't sure if it was the ignition or my 650 DP. Runs even better now though with a new Summit carb, Digital-6 box, and MSD 8361 distributor.
Sucks I had to put the long spark plug wires back on though.
Attached Thumbnails Accel Corrected HEI Cap-012.jpg   Accel Corrected HEI Cap-001.jpg   Accel Corrected HEI Cap-005.jpg
Old Apr 6, 2011 | 09:54 PM
EvilCartman's Avatar
Car: '82 Z28
I've always heard bad things about those types of caps.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midias
Aug 15, 2015 05:07 PM
