1st rebuild 305 noob needs help !!!!!
Old Feb 19, 2011 | 05:53 AM
84firebird4me's Avatar
Car: 84 firebird TA sport coupe 305 quad
Engine: 305 l69 quadrajet carb
Transmission: chevy five speed automatic
i have a 305 to put back into my 84 ta its the original 5.0 h.o. l69 i have never heard the engine run but the symptom is a knock suspect is a rod bearing thou i dont know which piston ??? i have the pan down and am gutting the block any advice on how to tell which bearing it might be ? should i look for scarring on the cam shaft the bearing being bent or scarred or misshaped??? advice is needed here gentlemen i have never torn down an engine this far and i am way over my head at 21 i dont have buddys to show me the way please shine a light on my situation for the love of my bird !!!!
Old Feb 19, 2011 | 06:02 AM
fordspanker's Avatar
Car: 92 Camaro Vert, 91 RS
Engine: 355ci
Transmission: TKO 500
Axle/Gears: 10 Bolt 3.73 posi
Re: 1st rebuild 305 noob needs help !!!!!
You should be able to grab the rods by hand, if a bearring has excessive play you should be able to feel it, then remove the caps and check the bearrings and crank for damage
Old Feb 19, 2011 | 07:20 AM
okay i was under there before work tonight and i seen the piston bottoms they have bolts in them undo those bolts and take the "caps" off then feel for the loose one it wont be much from what i understand but it will have play check the surrounding area for scarring and thats the one to replace if it is smooth will i be okay with replacing it or if i do that will it just spin out again ? and if it is not smooth it needs mechined and oversized bearings right ?
Old Feb 19, 2011 | 07:23 AM
what does this cap look like post a pic if you could please im trying to understand this im doing this myself for the first time
Old Feb 19, 2011 | 11:51 AM
Engine: 355ci
I will not be home until tomorrow night. You want to check for play before removing the caps. try moving the rods from side to side and tp to bottom, try them all and see if any feel different.
Old Feb 19, 2011 | 12:25 PM
91BirdFreak's Avatar
Here is a quick pic, this should help!
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Feb 21, 2016 01:29 PM
fbirdroller
Sep 2, 2015 10:27 PM
someone972
Aug 30, 2015 12:52 AM
hokis
Aug 9, 2015 03:57 PM
