No A/C, how do I mount power steering?
Old Mar 2, 2011 | 02:32 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
Not sure if this is the right forum for this, but I need help figuring out how to mount my power steering on a 70s 350 block. I have headers too, if that matters. Do I need a special bracket for this or what?
Old Mar 2, 2011 | 02:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No A/C, how do I mount power steering?
I tried using the factory brackets without the A/C on them, but something with the A/C part of the brackets keeps the whole busines stable, and without the A/C part, I never had any luck. (I swapped in an older motor and ditched my serp setup for v-belt setup)
I ordered the March P/S pump bracket and it does fine. Settle for no less than March, I tried several other brands (trying to save a buck) and none worked. Best to bite the bullet and spend the $105 for the March and save the hassle of cheaper brands not working.
Old Mar 2, 2011 | 02:56 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
http://i278.photobucket.com/albums/k...rd/swap058.jpg
Mines working just fine without the ac bracket. Had to add a spacer for the top bolt, thats it. The belt does want to bend the bracket with only the two mounting points, but its strong enough to be fine.
Old Mar 2, 2011 | 06:06 PM
Car: 1985 Trans Am
Engine: 360
I see two kinds of brackets that March has, a Saginaw and metric. I have no idea what the difference is between the two.
Old Mar 4, 2011 | 02:10 AM
EvilCartman's Avatar
Car: '82 Z28
Same way I've been running mine for years. The PS belt has come off once and I think it was because the alternator belt got sucked in when it flew off lol. No belt troubles for 2 or 3 years now, they've all stayed on up to 7500 rpm.
Old Mar 4, 2011 | 11:00 AM
Car: 1992 RS
Engine: Carbed 350
I'm guessing my issue with trying to use the stock brackets was maybe the bracket I had was just too old - it wasn't very stiff, and it wobbled quite a bit. I tried several different way of bracing it, and finally gave up.
The March bracket I used is: http://www.summitracing.com/parts/MCH-20165/
I'm sure that Billet Specialties and other 'better' brands work well too. The 'junk' I tried was an ebay bracket that 'looked' exactly the same as the March, and some other cheaper brand that looked identical, and neither actually worked (wrong size spacers included, wrong hole locations, etc.) - that's why I 'gave up' and went with the March - I knew they'd stand by their product and would assist with phone tech support if needed.
Old Mar 6, 2011 | 10:59 AM
Car: 1985 Trans Am
Engine: 360
Were you able to use the stock 2V pulley with this bracket, or did you have to buy one to go with it?
Old Mar 6, 2011 | 11:31 AM
Car: 1992 RS
Engine: Carbed 350
My pulley on the P/S pump is actually just a single V pulley.
Originally, my car had the serp setup (1992 car). But I swapped in the carbed 350 and got rid of those huge ugly serp brackets. Now I'm setup like a 1987 car, with alternator on pass side and using the 1/2 serp 1/2 v-belt kinda setup. I run a serp-looking belt (ie a wide flat belt) from crank to w/p to alt, and a skinny v-belt from crank to w/p to p/s.
That way, if one belt breaks, I still have w/p running to keep engine cool until I can get to a store to get another belt. I have no smog pump or A/C.
For my car (since it was serp originally), this meant replacing w/p pulley, changing to an older p/s pump, and older alt.
Old Mar 8, 2011 | 06:35 AM
BloodyBlueBird's Avatar
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
This is how mine is set up too. The only difference is that i already had the half serp half v-belt thing stock. I've been reading that this way is incorrect because of the rotation of the water pump?... I may have just confused myself and read them wrong. I'm just using a stock replacement water pump as of right now... Can i not run my setup like this or what? because of the rotation of the water pump? I'm so confused and i kinda thread jacked
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
