crap in cylinder walls
Old Mar 5, 2011 | 08:35 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I got some dust and little bits of leaves sitting on top of the pistons and walls, can I just get like an air compressor can and just blast it out?
Old Mar 5, 2011 | 09:43 PM
IROCyou86's Avatar
Car: 1983 Z28
Engine: 305 LG4 soon to be FRANKENSTEIN L69
Transmission: T-5 NWC
Re: crap in cylinder walls
at least remove it by hand if you dont have air. put a generous amount of oil in each of the cylinders. Then crank it over by hand and remove the rest of the debris. Then put your heads back on before next fall.
Old Mar 5, 2011 | 10:19 PM
0pyders's Avatar
nono I meant like go to office max and get that compressed air stuff and just spray it all out, would that work?
Old Mar 5, 2011 | 11:34 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
to an extent yes, but putting oil in the cylinder and turning it over by hand will leave all the microscopic dust and debris still there after the air spraying in a ring at the extremity of the piston travel for you to wipe out. clean that out with a brand new paper towel or terry cloth. No napkins or anything that will leave dust (not that it's incredibly harmful)
Old Mar 5, 2011 | 11:40 PM
0pyders's Avatar
are you saying i should use oil and towels to get rid of it instead of air?
Old Mar 5, 2011 | 11:58 PM
84redta's Avatar
if you want, pick the big parts out by hand, and then oil up the side walls, maybe some wd40, just to coat all the sides so that the piston rings are coated, and then do that to all open/affected cylinders, after each cylinder and cylinder wall is nicely coated, turn it over and let each cylinder come to the top and go back down, wipe up the crap, and close it all back up so nothing else ever gets in there other than fuel and air (while its running of course )
Old Mar 6, 2011 | 01:16 AM
0pyders's Avatar
thanks for helping me you made me feel better.
Old Mar 6, 2011 | 02:48 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Dry compressed air would be best. After removing as much debri as you can by hand. You dont want to send it flying into the cam valley where it will end up in your oil either. The mechanical cleaning being suggested will probably leave debri in the gap between the piston and cylinder above the top ring. Any foreign material in the cylinder can cause scuffing and reduce ring seal. If all you can do is the canned air, remove as much debri as you can by hand and then use the air for fine cleaning. Then, as suggested, lightly coat the cylinders with oil and get the heads back on. In the future when you have a motor torn down, cover it tightly to prevent this kind of contamination.
Old Mar 6, 2011 | 02:55 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
i would use light air and maybe a thin amount of Kerosene on a microfiber rag and be very very gentle and careful. Or i would just get the heads redone. Any type of micro sized anything could scratch your cylinder and make the whole thing smoke like crazy from the amount of oil it gets
Old Mar 6, 2011 | 02:08 PM
torque_is_good's Avatar
i need to know why nobody suggested to just pick up the block over your head and shake vigorously until all debris fell out
Old Mar 7, 2011 | 12:42 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Oh man! Why didn't I think of that!
Old Mar 7, 2011 | 01:59 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Like the rope trick to keep a valve from falling out, use a 100% cotton rag for a wipe down. Use like wd40 on it to grab stuff, any cotton fibers left behind will burn off clean.
Old Mar 7, 2011 | 07:51 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
shop vac
Old Mar 7, 2011 | 09:11 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Originally Posted by 86LG4Bird
shop vac
Thats what I was thinking too
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
