new cam for 355 rebuild
Old Mar 7, 2011 | 04:51 PM
86/outlaw's Avatar
Car: 1986 camaro Z28
Axle/Gears: 3.23 posi
Hi all
im new to all this so ill tell you what i have im building a 1986 camaro with a 350 tpi i have already bored it .30 over and going with flat top pistons
and the stock crank and rods its a 2 bolt main roller block .
now what i need help with is what cam to go with that i can use the stock tpi set up?
i know it runs out of breath around 5k and i would like to stay with a roller can any help is appreciated
Old Mar 10, 2011 | 05:53 PM
86/outlaw's Avatar
Re: new cam for 355 rebuild
? anyone
Old Mar 10, 2011 | 06:30 PM
The Comp "502" grind 08-502-8 is known to work pretty well on an otherwise stock TPI 350.
Stick with cams that are specifically designed with TPI in mind, as TPI puts some unique constraints on the cam. Cams that might work GREAT with some other induction systems, can often fall far short of optimum with TPI.
Old Mar 10, 2011 | 07:25 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
That's the same setup my motor is. I used Comp Cams xr264hr cam and lifters. The grind on it is 08-501-8. It's what their tech guy recommended. I am no expert on cams though, so just some info for you to consider.
JHX
Aug 29, 2015 02:30 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
