Coolant leak from one of these hoses
Old Mar 11, 2011 | 03:25 AM
Smashton's Avatar
Car: 1987 Camaro Iroc Z
Hey everyone. I recently picked up an 87' Iroc and had noticed a pool of coolant underneath it. I checked under it today, and I looked for where the leak was coming from. I noticed there are two hoses, side by side, and the one on the top is leaking coolant. I haven't the slightest clue though, as to what and where these hoses go to. I checked a couple of parts stores, and even showed them pictures, and they didn't know either.
I have attached a photo with a red box around it, to point out what I mean.
If anyone could help me identify and fix the problem, that would be fantastic!
Thanks! (not my car in photo...and sorry if it is a little hard to see.)
Old Mar 11, 2011 | 03:35 AM
The B-Man's Avatar
Car: 1983 Pontiac Trans Am
Engine: Modified 350 4-Barrel
Transmission: 700R4 Stage 3 Shift Kit 3500 Stall
Axle/Gears: 3:73
Re: Coolant leak from one of these hoses
Not to sound like the smartass but why can't you just follow them to see where they go. I can't think of what they'd be for right off hand. Sorry buddy.
Old Mar 11, 2011 | 03:41 AM
Smashton's Avatar
Haha, no worries. Well, I did try and trace them..and they run into the engine block somewhere...and connect to something within that picture.
Old Mar 11, 2011 | 01:14 PM
Look like the lines to the oil warmer.
Old Mar 11, 2011 | 01:24 PM
Smashton's Avatar
Isn't there supposed to be oil running through those lines than? Then again, I did read somewhere that those lines are supposed to have coolant running through them. Is that right? And when I went to Shaw GMC, they said the lines were supposed to be metal, and the one that's leaking is rubber?
Old Mar 11, 2011 | 04:11 PM
Right: they carry water, and they are (were) metal. The oil only goes through the little sandwich adapter between the block and the filter.
Most likely, they already rusted through once, and somebody changed out all or part of it, with rubber.
Old Mar 11, 2011 | 07:13 PM
Smashton's Avatar
Thanks for the info everyone. So, now that's sorted out...I asked around and someone said I can get them replicated from a shop here in Calgary. I was wondering, how would I go about taking the hoses out? Should I drain the coolant, and then take them off? Or, should I just order the aluminum reproduction ones off of Hawks?
Old Mar 11, 2011 | 10:23 PM
torque_is_good's Avatar
Calgary, that explains the condition of the underside
your struts need to be replaced
your front sway bar bushing clamp is rusted
the bushings need to be sprayed with restorer or at least silicon
sway bar bushings are probably collapsed and need replacement on the outer ends.
front end is out of alignment
you need tires
add grease
I hope the sale price was under $1,000 USD unless of course the paint and interior are in pristine shape.
If that is the condition of the suspension then I shudder to think about just how well the drivetrain was maintained.
Old Mar 12, 2011 | 12:55 AM
Smashton's Avatar
Yeah...good ol' Calgary. I forgot to add...this isn't my underside...I just got the picture off the web as a reference. If that's bad...then mine is worse! Luckily, I got the car for free...
Anyways, I took a look under again, and I'm thinking that the harmonic tensioner gouged the hose. Has anyone here had any experience replacing the oil cooler lines?
Thanks!
Old Mar 12, 2011 | 01:26 PM
The B-Man's Avatar
Axle/Gears: 3:73
you need tires
add grease
That car looks pretty solid to me. You should see some of the cars driving around New Brunswick. Wherever you live you must be spoiled with your car conditions
Old Mar 12, 2011 | 04:49 PM
moved from New England to Florida. It's night and day what older cars are like underneath.
Bubbajones_ya
Jul 6, 2024 08:32 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
