What are these Connectors on the Head?
Old Mar 11, 2011 | 05:10 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
I think one if them is a coolant temp sender to the coolant gauge. What is the other sensor then?
Attached Thumbnails What are these Connectors on the Head?-p3150158.jpg   What are these Connectors on the Head?-p3150160.jpg
Old Mar 11, 2011 | 05:18 PM
Re: What are these Connectors on the Head?
A is the temp gauge sending unit.
B has to do with the HVAC... when the head temp reaches some kind of "normal" range, the blower is kept running by it at a very low speed, even when the dash switch is off.
Old Mar 11, 2011 | 05:21 PM
oamhmad's Avatar
Car: 84 Trans AM
Thanks a lot. That explains why I can feel blower sometimes even when the switch is off.
On another note, I'm trying to sell these 416 heads. Any idea what they are worth? or should I take them to the junk yard?
Old Mar 11, 2011 | 05:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Don't junk them - they are good heads if ported/polished - keep them or sell them.
BTW - heads are the same either side, so they can be flopped from left to right. Pic A is a coolant temp sender as mentioned, so it must have come off driver side. But if you put that head on pass side, in a 3rd gen it would be the fan switch location.
Old Mar 11, 2011 | 07:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't had a car with the "B" switch, but I thought it had something to do with the cowl inlet on TA's.
deracer
Apr 11, 2016 12:04 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
