Striker fell out, can't close door.. tap plate down in 1/4 panel
Old Mar 13, 2011 | 12:55 AM
DomesticCheese's Avatar
Car: 1984 Chevy Camaro & 1988 Trans Am
Engine: H/C/I LS1 & 305 LB9
Transmission: T56 Magnum-F 2.66 & Stock T5
Axle/Gears: QP 9" TruTrac 3.70 & Stock 10bolt
Old Mar 13, 2011 | 08:36 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: Striker fell out, can't close door.. tap plate down in 1/4 panel
you should be able to retrieve the striker plate from the speaker well I would think.
means taking a few things out first but I'm sure you should be able to do it.
How did it get installed in the first place?
Hope you get sorted.
Old Mar 13, 2011 | 09:30 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Try taking the door jamb vent out first and try a magnet on a string, just one screw I would thing easier than dropping the speaker. If you can't get the phillips screw out, then yes, you should be able to get it from the speaker hole with the speaker removed.
Old Mar 13, 2011 | 10:56 PM
Alright, thanks I'll try that tomorrow.. worst case scenario I might just try to weld the striker in, it'd at least be a permanent fix but I'd worry about being off with my measurements with it
rgauder
Nov 30, 2018 07:36 AM
Gecz28
Mar 26, 2016 04:07 PM
formula forever
Jun 28, 2011 10:39 PM
92VertJosh
Mar 26, 2009 10:06 PM
wm_sorg
Sep 19, 2000 11:47 AM
