bad day at island raceway nj please help!!!
Old Mar 20, 2011 | 08:39 PM
keebs98's Avatar
Car: 1985 iroc z
Engine: 350 5.7
Transmission: 700 r4
Axle/Gears: 373
my car is loosing coolant but not leaking its stalling shaking and back firing any ideas ive filled my coolant reserve 3 times in 2 days???
just had the 700r4 rebuilt last week please help !
Old Mar 22, 2011 | 04:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What does the oil on the dipstick look like?
Old Mar 22, 2011 | 07:55 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: bad day at island raceway nj please help!!!
that and after its running a bit drain some out of radiator and what color is it? Also what does your exhaust smell like? (As in does it smell like coolant)
Old Mar 22, 2011 | 08:13 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Head gasket or intake manifold gasket.
Old Mar 22, 2011 | 08:26 PM
keebs98's Avatar
Car: 1985 iroc z
Engine: 350 5.7
Axle/Gears: 373
it looks fine i didnt see any coolant
Old Mar 22, 2011 | 08:38 PM
keebs98's Avatar
Car: 1985 iroc z
Engine: 350 5.7
Axle/Gears: 373
well i left it at an sts up where it broke down and the guy called me up monday and said the problem he found was that the coil fell out of the distrubutor and the screws came loose and he couldnt believe it was still turning over ,so he but a new distributor on and he said it was fine ...but i asked him abount the suuden loss of coolant in the reserve and he wasnt sure ...then he calls me back and said the water pump was leaking and needed to be replaced and said the vaccum from the reserve was sucking all the fluid out but im not having him do the water pump cause hes trying to charge me 300 bucks id rather to it my self so does that sound like a reasonable explaination or make sense to any one or do you still think its something worse ? also does anyone use a hypertech chip on their 350 and is it normal for the check engine light to always be on ? on warmer days it wont come on and my car idles higher and looses alot of power???
Old Mar 26, 2011 | 08:13 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Could be a bad coolant switch in the intake manifold, so when its really warm out, your car is thinkings its -40 out, just a thought, but check the codes and that will unvail clues
Old Mar 26, 2011 | 08:43 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Possible coolant temp sensor or manifold temp sensor. Yes, the water pump leak would account for your coolant loss.
redmaroz
Apr 25, 2017 07:14 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
92GTA
Apr 9, 2016 07:39 AM
Orr89RocZ
Feb 13, 2016 10:04 PM
Winchester1094
Aug 18, 2015 10:23 AM
