how do i get familiar with the car plz help
Old Mar 25, 2011 | 02:41 AM
5.7chevykid's Avatar
Car: 82 berlinetta camaro
Engine: 350 5.7
Transmission: auto
i want to learn everything bout my camaro how do i check the eengine model transmition etc. ive always loved camaros but never realy learnd much about them plz help
Old Mar 25, 2011 | 03:57 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: how do i get familiar with the car plz help
Buy a HAYNES manual from your nearest autoparts store. It will give you a good summary so to speak about your car that you can read about. Everything else can be found on here more than likely.
Old Mar 25, 2011 | 04:00 AM
Engine: 350 5.7
Transmission: auto
thing is the owners before me had swapd it its a 350 now it was a 6cyl and i wana find out wat kinda transmition i have and stuff
Old Mar 25, 2011 | 07:56 AM
torque_is_good's Avatar
what ever became of the issue you were having? Did someone take it to the shop and get it fixed? If so, what was the result?
Old Mar 26, 2011 | 07:12 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
read the tech articles and use www.google.com its ur friend
Old Mar 26, 2011 | 07:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Buy the factory shop manual from Helm's Publishing. It is the absolute best resource for every system on the car. If the engine has been swapped, the factory book will help you see where the original and the swap in meet each other.
Old Mar 26, 2011 | 08:05 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I was going to say GM shop manual as well. Haynes/Chiltons are comic books compared. I have 2. 1 for show, and 1 has the cover covered in duct tape that I use/read when I need it.
Old Mar 27, 2011 | 12:08 AM
1969RSSS's Avatar
Car: 69 Camaro,88 T/A,03 Prius
Transmission: M22
Axle/Gears: 12 bolt 3.73 posi
Open hood and dig in, No I'm kidding. read some mags, tech articles, threads here and try and gain some basic knowledge (what items are, IE radiator, alternator, p/s pump, spark plugs, air cleaner, valve covers) and learn some basic safety concerns IE not working on a running engine unless you know what your doing, Not touching hot parts with bare hands, using a jack and jack stands ( do you trust a 15 cent o-ring with your life?) etc. And have some fun!!!!
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
