Speedometer question!
Old Mar 29, 2011 | 01:54 PM
unseenT/A's Avatar
Car: 1987 Trans Am
Engine: Patriot Performance 383 500hp
Axle/Gears: Dana 44 4.09's
I have a 1987 Firebird Trans Am,i swapped transmissions and did major work to the car and before i go crazy taking the dash apart i want to know if this is an electronic sending unit or it is infact cable driven which i'm hoping.
Would be amazing to have a speedo again
Thanks in advance!
Old Mar 29, 2011 | 02:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Speedometer question!
I'm pretty sure it's cable driven, think electric was later in years. But I'm no expert. Before tearing into dash, why not look at the tranny and see? Cable speedo won't have an electrical connector on the tailhousing.
Old Mar 29, 2011 | 02:11 PM
unseenT/A's Avatar
Car: 1987 Trans Am
I bought the car with the speedo not working,recently i just had a fully built TH400 installed so looking @ the transmission won't do me any good :/
Thanks for the input!
Old Mar 29, 2011 | 02:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The speedo will be electronic or mechanical and will require either wiring (VSS) or a cable on the trans tail shaft to make the speedo functional. Unless you stripped the wiring or the cable, one or the other should still be there.
Oh, some Birds went electric as early as 86.
JamesC
Old Mar 29, 2011 | 03:09 PM
unseenT/A's Avatar
Car: 1987 Trans Am
Thanks for the input so far
Old Mar 29, 2011 | 04:14 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
you can still tell if its elctric by looking at the driver side of the tailshaft , wires or no wires there will be the sending unit will have a black plug on it with one retaining bolt...even if it was rebuilt IT HAS to be there if its electric vss otherwise youd have no trans fluid hope that helps
Old Mar 29, 2011 | 04:43 PM
unseenT/A's Avatar
Car: 1987 Trans Am
There is a totally different transmission in there now,a brand new TH400
Looks like i'll just have to take apart the dash and see!
Old Mar 30, 2011 | 04:04 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
you most likely have an electronic speedometer. If you had mechanical you'd see a thick cable hanging right next to the transmission on the driver's side.
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
