28 years of guzzling gas and counting..
Old Apr 3, 2011 | 01:08 AM
Goofyfoot08's Avatar
Recently I found myself becoming the owner 1982 Z28 Camaro. She aint the prettiest, but she runs fairly consistently and came at a fair price. I was wondering though, what are the best ways to improve fuel mileage in these cars? She's completely stock, and gets a wonderous 14mpg on the highway. I know I shouldnt expect prius-esque figures, but any improvement is an improvement nonetheless. I thought a good start would be ditching the stock carb. Good call?
Old Apr 3, 2011 | 10:46 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: 28 years of guzzling gas and counting..
The best mods first would be over all tune-up, then high flow exhaust and cat, you cant beat the stock carb for mpg they have small primary's so when your crusin it uses less fuel
Old Apr 3, 2011 | 10:54 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
did 82s have a OD? thatd be the most MPG improvement if they didnt
Old Apr 3, 2011 | 11:20 PM
EvilCartman's Avatar
Car: '82 Z28
Not the autos, but it should have the lockup converter. I was getting about 21-22 on the highway with 3.42 gears and a non-lockup converter. Also had a comp cams XE256, headers, 3 inch single exhaust, performer intake and a Holley carb. The stock camshaft wouldn't hardly do anything above 3000 rpm, turns out it had 4 flat lobes.
Old Apr 3, 2011 | 11:28 PM
Car: 1990 camaro RS
Engine: 305 TBI
well OD is good for 2mpg or more usually xD
Old Apr 4, 2011 | 10:03 AM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
My 2.8mpfi gets about the same that's why I'm trashing it. I control Lockup through the ALDL when cruising in 3 or 4 gear. Its got a new maf new tps...cts is good...new plugs wires cap and rotor. Vacuum is good but the last time I changed the plugs they had an brown tint with gray ashy deposits around the electrode.
Old Apr 4, 2011 | 10:09 AM
Old Apr 4, 2011 | 04:07 PM
I appreciate your help. I've already started planning a bit with what I want to do. How complicated is the swap to LT1 disk brakes? What size holley carb were you using, evilcartman? I've played with small block fords a bit, but chevy's are a different animal. Any advice is appreciated as to what would be good mods to make moderate horsepower (300hp) and maybe remotely decent gas mileage. Even 20 would be amazing. And thanks in advance.
mustangman65_79
Sep 1, 2015 03:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
BurlyChev
Aug 16, 2015 09:08 PM
