Poping Noise
Old Apr 8, 2011 | 12:47 PM
steven72192's Avatar
Poping Noise
so yesterday i was driving my 83 camaro z28, stock 305, and noticed a dramatic decrese in power. it was like the car was bogging down, i also notcied my rpms were very high i was going about 10-15 mph and my rpms were already at 4000 or so. i thought it might have been a trans problem and so i checked my trans fluid and it was low, so i fiiled it up and the trans starting shifting better. as i took it for the test drive i hit the gas hard a noticed still a loss of power and heard a poping noise, so i brought it back to the house and checked for anything unplugged hoses, electrical connects and so on but everything is fine, what else could be causing this? please help
Old Apr 8, 2011 | 01:21 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: Poping Noise
clogged cat or take a look at the distributor to find the miss. let the car warm up and look at the cat, if it's glowing cherry red you found the problem.
Old Apr 8, 2011 | 01:31 PM
Re: Poping Noise
i dont think there is cats on the car it is a single exhaust and before i bought the car the previous owner made it into duel exhaust with the same exhaust mainifolds not headers. i also looked at the dis and unplugged and replugged in all of the wires what should i look for on the dis?
Old Apr 8, 2011 | 02:09 PM
theNMBR27's Avatar
Re: Poping Noise
Take the cap off and check the terminals/ rotor for corrosion.
Old Apr 8, 2011 | 02:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Poping Noise
I'd do a tune up - fresh plugs, wires, rotor, cap, and fuel filter. Usually "popping" ends up being backfiring, which in my experience usually points to an ignition issue (bad wire, fouled plug, worn cap/rotor).
Old Apr 8, 2011 | 07:36 PM
Re: Poping Noise
I just finised the tune up new plugs new wires new cap and a new rotor and still no luck. I took it for a test drive and wen I got on the gas just a little not even punching it it made the poping noise and seemed like it didn't want to go any faster.
Old Apr 8, 2011 | 08:02 PM
Car: 1992 RS
Engine: Carbed 350
Re: Poping Noise
Any chance you got the firing order off when replacing wires?
What about the fuel filter, did it get replaced?
Any stored codes in the computer?
I'm just throwing out things here to check.
Old Apr 8, 2011 | 08:10 PM
Re: Poping Noise
Fireing order is deff correct no I did not change the fuel filter yet and I do not have a computer in I took it out a while back when i eliminated emissions
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
