Backfiring issues. Please help ASAP
Old Apr 12, 2011 | 12:55 PM
CJ87's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
I have a '91 Camaro with a 3.1 V6, While car is in park & i throttle the car, she backfires. While in drive & i give her gas she bogs down a little bit. Can someone please help. I do have a small exhaust leak where previous owner cut out cat converter & welded straight pipe. Would this little issue be my problem?
Old Apr 12, 2011 | 02:59 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Backfiring issues. Please help ASAP
Backfires through the exhaust or intake?
Have you checked for vacuum leaks? Fuel pressure?
Old Apr 12, 2011 | 03:03 PM
CJ87's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
through exhaust. no vacuum leaks since i just replaced the EGR valve, fuel pressure seems fine. i was having timing issues but the way i fixed it was weird
Old Apr 12, 2011 | 03:44 PM
CJ87's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
[IMG]file:///C:/DOCUME%7E1/Chris/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]ok the diagram im showing is the firing order for my 3.1 Camaro. Thankx to 85SportCoupeto89RS for the diagram. Where number 3 is is where my number 1 is. Without removing or moving the distributor i moved the spark plug wires from where they were to where they should be. It got alot worse! So i put the spark plug wires back to the way they were. where number 3 is on the diagram is where my number 1 is & count 2,3,4,5,6 goin around from there. so 1 is where 3 is, 2 at 4, 3 at 5, 4 at 6, 5 at 1, 6 at 2 & the funny thing is........ It started right up without a problem. So like i said, the way i fixed my timing issue is weird.
Attached Thumbnails Backfiring issues. Please help ASAP-firingorderofcamaro.jpg
Old Apr 12, 2011 | 05:21 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
I bought a car once with similar trimming issues, but it was due to timing chain stretch and a fugded dizzy install. The exhaust leak shouldnt cause a huge backfire if its minor. It also shouldnt cause a bog under load. IMHO, you need to install the dizzy and wires correctly to insure correct ignition timing.
Old Apr 12, 2011 | 05:56 PM
CJ87's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
ok i just took her on her first test run since tranny was rebuilt, EGR valve replaced & timing close. i still feel timing might be a hair off & i'm having a tiny bit late of a throttle response. I wasn't really able to put full throttle to the floor bcuz of neighborhood but while in park the car does have a tiny back fire. i could be mistaking it for a misfire. i'm going to record the sounds & post on youtube so u can hear. But i know for a fact that i do have two small exhaust leaks at each end of the welding where the previous owner cut out cat converter.
Old Apr 12, 2011 | 06:06 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
That's how mine acted when my fuel pump went out. Changed it and was good to go. never had a problem with it backfiring or bogging.
Old Apr 12, 2011 | 08:59 PM
CJ87's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
ok, i have finally uploaded my car to youtube. please check this out & tell me what u think.
http://www.youtube.com/watch?v=3LFBVL9mPqg
Old Apr 12, 2011 | 09:25 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
camarosrock may be right mine was acting similar (i have a 91 305 tpi) its currently in the shop having a new fuel pressure regulator as well as a pump...its coomn for the v8's and v6's so hook up a guage and check your pressure
Old Apr 12, 2011 | 10:28 PM
CJ87's Avatar
Car: '91 Camaro RS
Engine: 3.1 V6
where can i find a gauge & what is it called?
Old Apr 12, 2011 | 10:42 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
I thought you'd checked it already when you said it seemed ok.
Any parts store should have one. Even Sears. Ask for a fuel pressure gauge. Make sure it can register over 60psi. There's a low pressure variety for carbed motors that will not work for your application.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
92projectcamaro
Sep 24, 2015 08:09 AM
Racerx974
Sep 19, 2015 10:16 AM
