Books how to rebounds rebuild 350s
Old Apr 15, 2011 | 06:11 AM
Reddeath210's Avatar
Well I want to rebuild a 350, but I have never done it before. So I am looking for a book on how to do it. Somthing like a hanyes or a chiltons any help is appreicated
Old Apr 15, 2011 | 06:13 AM
Re: Books how to rebounds rebuild 350s
Sorry I am on my.cell phone and it snuck in an extra word in the title
Old Apr 15, 2011 | 07:06 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
My advice would be to get the block remachined and the cam bearings replaced. If you want do the rest on you own, go from there. I'll try to find you a couple of titles 0f books I've used before.
Old Apr 15, 2011 | 07:14 AM
rffy's Avatar
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
This haynes book I have used. It's easy to understand if you haven't done it before.
http://www.amazon.com/Rebuild-Small-.../dp/188408995X
Old Apr 15, 2011 | 07:16 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
http://www.amazon.com/Build-Small-Bl.../dp/0760310963
Old Apr 15, 2011 | 07:20 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Haynes and Chilton usually cover the rebuild process. They cover them from an OEM spec though. Some machine shops will do assembly for you at an extra cost also.
If you're wanting to do it yourself there are a few tools that I consider a must. Torque Wrench, Engine Stand (preferably one that you can rotate the block on easily), ring grinder, piston install tool, crankshaft socket tool (to turn it over easily to install rods), balancer installer, and a hoist to get the old motor out and the new one in. I can lift a sbc out of a town car trunk unassembled by myself but trying to move/carry an assembled one is another story.
Also a clean room is perfered. I built my current motor in my bedroom at my parents house since 1/2 of the room was bare cement floor.
Old Apr 15, 2011 | 01:22 PM
Thanks for all the help guys I really appreicate it
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
Eric-86sc
Aug 24, 2015 09:01 PM
hayesaw0210
Aug 23, 2015 11:15 PM
