need timing adjustment help
Old Apr 17, 2011 | 04:26 AM
5.7chevykid's Avatar
Car: 82 berlinetta camaro
Engine: 350 5.7
Transmission: auto
how and what do i need to adjust my timing for better horsepower?
Old Apr 17, 2011 | 06:56 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: need timing adjustment help
timing gun, wrench or socket for the dizzy hold down and thats about it.
disconnect the wire for the dizzy advance(dont remember which one it is) loosen the hold down hook up timing gun to number 1 plug wire, start car, aim at timing mark, and adjust dizzy for timing as desired. then tighten hold down bolt plug wire back in and call it good!
Old Apr 17, 2011 | 07:46 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Thats HOW you adjust it.
You might want to dig a little deeper into some of these threads (based on your engine specs) to see WHAT you want to adjust it to.
Old Apr 17, 2011 | 08:39 AM
well he didnt ask what to adjust it to.....yeah look up what other people have set theirs at
Old Apr 17, 2011 | 09:33 AM
torque_is_good's Avatar
the OP asked how t adjust the timing for better HP.
That is called advancing the timing and be sure you've purged all of that cheap 87 octane you've been running and have been running 91 or 93 octane for a tank.
Old Apr 17, 2011 | 12:15 PM
Engine: 350 5.7
Transmission: auto
NICE! thank you all so much
Old Apr 17, 2011 | 12:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Yes. Run premium and set timing to 10 degrees. If you hear pinging, reduce timing 2 degrees and retest, repeat until pinging is gone. It helps if there are no carbon deposits from lugging around town. As far as the process of actually adjusting timing, after you set timing, be sure to clear ECM codes by disconnecting the battery for 30 seconds. Otherwise your ECM may run in EST bypass mode and you won't achieve full advance.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
