1991 Z28 High Idle
Old Apr 21, 2011 | 09:19 AM
StrahlZ28's Avatar
Car: 1991 Z/28
1991 Z28 High Idle
Okay, I put a new fuel regulator bladder in last year when suddenly I had a hard start and fuel in my vacuum lines. I strung new vacuum lines throughout the engine and replaced my plenum and runner gaskets, and the throttle body gasket. Fuel pressure is normal at about 37-38 PSI and I can't hear any vacuum leaks.... WHISKEY TANGO FOXTROT OVER?!?!?!
Old Apr 21, 2011 | 11:49 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: 1991 Z28 High Idle
Since vacuum leaks aren't always audible I'd spray some carb cleaner of the engine just to be safe, vacuum leaks can cause some funky stuff. Otherwise check your idle air control passage/wiring.
Old Apr 23, 2011 | 12:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What do you consider a 'high idle'? What was it idling at before? Hot, cold, etc?
Old Apr 23, 2011 | 02:59 PM
StrahlZ28's Avatar
Car: 1991 Z/28
Still haven't figured it out. Starting to suspect my IAC. But it used to idle at 650-700 now it's up around 1500.
Old Apr 24, 2011 | 02:18 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I replaced my IAC, and it cured it. It was an educated guess.
Old Apr 27, 2011 | 11:16 AM
StrahlZ28's Avatar
Car: 1991 Z/28
Well I got a scan tool from a guy at work and I have response from my IAC, MAP, and TPS which are all within range. Now the idle on the scanner said it was 1000-1100 (cold) and my RPM gauge said it was closer to 1500-2000. The desired idle (according to scanner) was 3350. Any ideas?
Old Apr 27, 2011 | 01:49 PM
Did you let it warm? I'd be curious to see what your scan tool reads after the engine is warm, and what your own tach reads. A cold engine will run high. My TBI runs about 1500 when cold. (I'm guessing). After the engine is warm, it settles back down to around 700 according to my tach.
Old Apr 28, 2011 | 08:11 AM
StrahlZ28's Avatar
Car: 1991 Z/28
My 1992 RS 25th Annv. did that too when she was cold. I never had that issue with the TPI though. I'm moving her out of storage this week, that should warm her up and I'll see what happens.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Dialed_In
Aug 20, 2015 01:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
