Fuel pump wont prime.
Old Apr 22, 2011 | 04:47 AM
86recaroTA's Avatar
Car: 1986 Trans AM
Drove my girlfriend to work hit a pothole which caused my guage fuse to blow, put in a new fuse and staryed the car to see if it was gonna blow again. Car staryed right up so I went and sat and ate, went to leave like 2 hours later and the car wont start. Turn the key and dont hear the fuel pump prime. Took the cover off the relay and the yellowish paper inside the relay is ripped, does this mean the relay is bad? Is there a way to rig it so I can atleast get the car home, im stuck with no parts store in walking distance and only a small socket set. Or is there something that couldve came loose cuz of the pothole? Is there a fuse somewhere than under the driver dash? Thanks in advance.
Old Apr 22, 2011 | 05:20 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: Fuel pump wont prime.
check the fuse between the battery and radiator, behind the fan relay.
Old Apr 22, 2011 | 06:36 AM
86recaroTA's Avatar
Car: 1986 Trans AM
Anychance your wearimg shiny armor,lol. Your my hero for the day. But, the fuse wasnt just blown it was melted what could cause it to melt? There was a 30a fuse is that the right size?
Old Apr 22, 2011 | 08:13 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
the factory manual for my 89 says it is a 20 amp.
Old Apr 25, 2011 | 07:48 PM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
im having the same problem with my 2.8 i was gonna replaced the unit through the trunk i changed my mind cuz the bolt didn't move so i put it back in. i turn the key it primed and started the car it ran then the pump stop and so did the engine. now it won't prime or start HELP!!!!! Its got a new relay and pump...
Old Apr 27, 2011 | 08:46 AM
BOSS HOGG LOU's Avatar
Car: 87 IROC Z28
Engine: 5.7 TPI
Axle/Gears: BW 9 Bolt
I am going to check that fuse when I get home. My car is doing the same thing right now. My fuel pump works, but won't prime. The car runs momentarily when a shot of starting fluid is sprayed. I replaced the fuel pump relay and all the fuses under the dash look good. I'm going to check the fuse 89RESTO is refering to, Fuel Pump/Oil Pressure Sending Switch, then maybe the distributor. Anything else I should look for guys?
Old Apr 27, 2011 | 09:22 AM
Found it that was the culprit ...smh
Old Apr 27, 2011 | 09:41 AM
Car: 87 IROC Z28
Engine: 5.7 TPI
What was the culprit? The fuse? I hope that is my issue. I need to get this bad boy running so I can clean it up for G15.
Old Apr 27, 2011 | 11:09 AM
Yeah try that I know I blowed that fuse twice
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
