Engine stalls when going into gear when warmed up
Old Apr 22, 2011 | 06:27 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Hey guys and gals. Here's my problem. I just replaced the head gasket on my 91 fbird 305 TBI Auto trans. Once I got the timing right it fired right up and ran good. Unfortunately when I tried to put it in gear it stalled. A few hours later I thought I'd try it again so I fired it up and put it in gear and to my surprise it didn't stall. However when it warmed up it stalled when I shifted into reverse or drive. I checked and made sure the vacuum lines were all attached, even replaced the worst of them in the process of putting it back together. I put only 2 gallons of anti-freeze in it. Should it have been more, and could this be the problem? It didn't overheat. All other fluids are good. Any help you could give would be great. Thanks!
EDIT - I did notice that the oil pressure sending unit next to the oil filter was broken. Could this be part of the problem?
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
