Need Help Real Bad Camaro Iroc-Z
Old Apr 25, 2011 | 09:19 PM
Alpine1987's Avatar
Car: 1987 Camaro Iroc-Z
Engine: 350 5.7
Transmission: 5-speed
Hey there everyone I have 1987 Camaro Iroc-Z all redone ground up the 350 inside is all rebuilt,New SparkPlugs,New Spark Plug Wires,New Fuel Filtter,Knock senor,New Coolant Temp Senor.
Here's the problem is my car runs fine drives fine i was driving it all day and i parked it inside my gaurge and in the moring i come to start it would fire up and die right away but if i keep my foot on the gas pedal it would keep running fine with out any problem but once the foot is off it shuts down on me DON'T KNOW WHATS GOING ON it ran fine just happend out the blue and i also cleaned the Air IDLE Senor right by the Thorttle Body Help Me Please Thanks.
Old Apr 25, 2011 | 09:21 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
Re: Need Help Real Bad Camaro Iroc-Z
check IAT connection, sounds like a choke issue
Old Apr 25, 2011 | 09:32 PM
Alpine1987's Avatar
Engine: 350 5.7
It's TPI By The Way
Old Apr 25, 2011 | 09:57 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
any trouble codes? try disconnecting the maf sensor and then running it
Old Apr 25, 2011 | 09:58 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Sounds like the Idle Air Control motor is bad or needs adjusting. Have you tried adjusting it?
Old Apr 25, 2011 | 10:05 PM
Alpine1987's Avatar
Engine: 350 5.7
No codes yet and the IAC i took it out today had alot of black stuff build up on it i cleaned it and everything but adjusting it no didnt noe i had to i thought i would just screw on
Old Apr 25, 2011 | 10:13 PM
No, it may need adjustment. there are instructions on the boards on how to adjust it. Do a search and you will find it. I bet that will take care of the problem. Also could be the throttle position sensor. You can check and adjust it using the process found on these boards as well.
Old Apr 25, 2011 | 10:19 PM
Alpine1987's Avatar
Engine: 350 5.7
What you think of the EGR soleniod maybe ?
Old Apr 25, 2011 | 10:28 PM
It's possible, but I have never had that issue (EGR) with any of my cars. I can not speak from experience on that one.
Old Apr 25, 2011 | 10:50 PM
Alpine1987's Avatar
Engine: 350 5.7
Just asking the IAC with the spring dose it move like in and out ? if dose when i was cleaning i tired pushing it did not move at all
Old Apr 25, 2011 | 10:56 PM
IIRC, it should be hard to move. I think its a "geared" motor, but I honestly cannot remember, as it's been about three years since I replaced one.
Old Apr 25, 2011 | 11:20 PM
Alpine1987's Avatar
Engine: 350 5.7
k thanks i will try adjusting it tomorrow
Old Apr 25, 2011 | 11:50 PM
I think that if you check/adjust both the IAC and the TPS that will end your problems.. Let us know.
Old Apr 26, 2011 | 09:35 PM
Alpine1987's Avatar
Engine: 350 5.7
Thanks man it was the IAC Sensor Works Sweet Now
Old Apr 27, 2011 | 02:08 AM
Right on! Glad you got it done!
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
reiderz iroc
Aug 13, 2015 04:57 PM
Vintageracer
Aug 11, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
