Gas pedal doesnt return
Old Apr 26, 2011 | 02:50 PM
HacksawHannibal's Avatar
Car: 1988 Camaro
Engine: V8 (Carb)
Im not tht familiar with cars so forgive me if this question seems a little ..dumb. My gas pedal doesnt return all the way. When i push the pedal and take my foot off it returns but not enough to stop the car for accelerating. Even in park if the car revs due to the pedal. Can some1 please tell me whats possibly wrong and what might need to be replaced. Thank you
Old Apr 26, 2011 | 02:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gas pedal doesnt return
The throttle spring may be broken.
JamesC
Old Apr 26, 2011 | 04:04 PM
Car: 1988 Camaro
Engine: V8 (Carb)
What exactly am i looking for bc i can find a "throttle spring" for the car. Does it have a certain name
Old Apr 26, 2011 | 04:58 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
yeah it's name is "throttle return spring"
You will find it connected to the motor in some way or another. Follow the throttle cable from the firewall to the motor. Whatever mechanism that cable operates will have a spring attached which forces return. If that's broken or disconnected in some way, you will experience the symptoms you described.
Hope this helps.
Old Apr 26, 2011 | 08:35 PM
Car: 1988 Camaro
Engine: V8 (Carb)
Hope this helps.
Thanks for the help. Im going to look at it tommorrow.
Old Apr 27, 2011 | 11:28 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Its on the drivers side of your carb. I can see itin your other post...
Old Apr 28, 2011 | 10:23 PM
Car: 1988 Camaro
Engine: V8 (Carb)
thx i found it and fixed the problem.. thanks every1
Old Apr 28, 2011 | 11:09 PM
TNT_Z28's Avatar
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
