Would like some advice on my future upgrades (This Summer)
Old Apr 26, 2011 | 10:32 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Hey guys, this thread is basically just gonna be me asking questions and you guys throwing in your opinions for what you think I could/should upgrade, tune, or replace on my engine, for better overall performance and power.
My Engine as it sits:
Chevy 350
Edlebrock 650 Carb
Highrise intake
high output distributer
vortec heads
flat head pistons
high rise cam
True exhaust
Upgrades Discussed:
-Suspension: struts, springs, shocks, sway bars, bushings, sub frams
-Brakes: Replace rubber lines
-Engine: Aluminum Pulley (anyone have anything against that?)
-Drivetrain: Rear end replace, posi 3.42+ and disc
I was thinking of an Aluminum Pulley kit? Something like BBK. What I have read is that can give somewhere around 5-15hp more.
Throw me your thoughts guys, I am trying to build a parts list for this summer so I can start planning.
Old Apr 26, 2011 | 11:40 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Would like some advice on my future upgrades (This Summer)
Sounds as if you have a nice engine as is and if I were to suggest a up grade It would be a rear end. A Eaton posi. with a higher ratio would really compliment what you are running.
Old Apr 27, 2011 | 02:15 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I agree with ronusmcmma; Rearend or, if money permits, a T-56 swap...
Old Apr 27, 2011 | 03:03 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Rearend agreed but if u dont have a tranny that will take the abuse i would start there, suspension upgrades
Old Apr 27, 2011 | 09:43 AM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
frame connectors and some good shocks, struts, sway bars, and your car will handle like its on rails!
Old Apr 27, 2011 | 09:44 AM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
o and some lowering springs.
Old Apr 27, 2011 | 12:54 PM
I have been looking everywhere for a posi 3:42/73. Also wanting to do the said suspension upgrades but don't even know where to start. I like the 1in eibach lowering springs. New sway bars and bushings. What else? What's the basic parts list for a suspension overhaul?
Old Apr 27, 2011 | 01:02 PM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Shocks
Struts
Sway bars
Frame connectors
Springs
Old Apr 27, 2011 | 01:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Agreed on the rear gears, although at least the 3.08's are a step up from 2.73.
My suspension recommendations:
Shocks/Struts
Springs (I really like my Eibachs 1" drop)
Redo the front end - this would be new ball joints, tie rod ends, centerlink, idler arm, maybe control arm bushings (the easiest way, if doing control arm bushings, is to get a set of control arms from another car, then have a local shop use their press to press out/in new bushings and ball joints all at once, then swap, and pass your control arms to someone else so they can do it the easy way).
Sway bars and bushings/endlinks - depending on what you have - generally folks want bigger, so measure what you got - if you already have 34mm in front, not worth swapping unless you get a real deal on a 36mm (largest).
Wonderbar if you don't have one - definitely!
Depending on brands chosen, that list will run you about $1200 (assuming good nice shocks/struts).
Brakes - have you ever replaced the rubber lines? It's amazing what a fresh set of rubber lines will do for stopping power!
Then, if time/money allows, SFC's and maybe a STB.
Old Apr 27, 2011 | 04:10 PM
Thanks for all the info. Thinking Ill replace the rear end at the same time as suspension overhaul. That sound smart?
Havent replaced the brake lines...hadn't thought about that.
Whats SFC's and STB? haha, sorry. Not clicking in my mind right now.
Old Apr 27, 2011 | 04:19 PM
Car: 1992 RS
Engine: Carbed 350
SFC's are Sub Frame Conectors
STB is Strut Tower Brace
Bubbajones_ya
Jul 6, 2024 08:32 PM
Fronzizzle
Feb 9, 2017 09:31 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
mrdevontay
Sep 2, 2015 08:04 PM
