Help!...there appears to be a small pond in my footwell...
Old Apr 27, 2011 | 11:59 AM
andy666's Avatar
Car: '92 Camaro RS 305 TBI
Engine: L03 305ci (5 litre) TBI
Axle/Gears: Standard
After noticing a small damp patch on the way to work the other day in the passenger footwell I thought nothing of it, untill I finished work and returned to my car to find it had now developed into a few cm of standing water. I soaked it up and left it till today where it repeated the same problem, so I soaked it up again on my lunch break.
While on lunch I also checked the radiator and the water level had dropped significantly, so I topped it back up and drove home. I've left it for an hour or two and just been out to check...and there is standing water appearing again. I've pulled the carpet back slightly to see if I can see where it's coming from and there is a very slight trial of water leading up behind the dash.
There has been no rain recently (strange for England I know) so that rules out a rain water leak.
Last weekend I replaced the y-pipe and in doing so snapped a stud on the passenger side manifold so had to take it out to drill. In doing so I removed some of the Air Con components. I'm confident I put everything back together as they should be and it's worth pionting out that the Air Con has never worked since I bought the car over two years ago (I don't think there is any gas in it)
Any ideas would be greatly appreciated!
Andy
Old Apr 27, 2011 | 12:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Help!...there appears to be a small pond in my footwell...
If it smells like coolant, then you need to replace the heater core.
If not, then you need to bait a hook and catch dinner! {pond}
Seriously - your heater core has gone bad. Replace. Can do it all from under pass side dash. There's 1 or 2 bolts that you cannot see, on the top of the plastic box that holds the core - they take 7mm socket - you just have to ...
1) watch a Yoga show for inspiration
2) stretch
3) get a 1/4 rachet, a 1", 2", 3" extension, and a swivel
4) say a prayer
5) twist yourself into a pretzel, reach up in there like you were birthin' a cow, and feel your way around in there, find the bolt, get the socket on it, hold your breath (so you don't move), and get those suckers out
Repeat to reassemble.
It's not all that bad - just takes a deep breath, and some patience, and the determination to breath (like a woman in labor) through the muscle cramp until you get it out.
Old Apr 27, 2011 | 12:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Might well be the heater core.
EDIT: The link to follow may be of some assistance:
https://www.thirdgen.org/forums/tech...e-82-86-a.html
JamesC
Old Apr 27, 2011 | 12:14 PM
wilmil's Avatar
Car: 83 Pontiac Trans AM
Engine: 305 CFI
Try you heater core. That is usually the culprit when there is a puddle on the passenger side.
Old Apr 27, 2011 | 12:41 PM
StrahlZ28's Avatar
Car: 1991 Z/28
2) stretch
4) say a prayer
You forgot the step for polish off a pack of cigarettes, and use some choice words.
Old Apr 28, 2011 | 01:37 AM
andy666's Avatar
Haha, thanks for the advice guys...I better get practicing on those yoga techniques, in the meantime I may just bypass the heating system and join the inlet and outlet pipes together with some copper tube. Can do without heating now the warmer(ish) weather is here.
Old Apr 28, 2011 | 11:45 AM
Car: 1992 RS
Engine: Carbed 350
Yeah, the choice words are a necessity I neglected to mention.
The cigs ... well being a smoker myself, I figured the increased rush might make his hands jittery, so I side-stepped that one on purpose.
But - a beer or 3 might circumvent the nicotene rush ... certainly won't hurt!
Old Apr 28, 2011 | 12:27 PM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
deffinately the heater core
Fronzizzle
Feb 9, 2017 09:31 AM
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
86IROC112
Sep 11, 2015 04:04 PM
hdis2002
Sep 8, 2015 02:52 PM
