High volume oil pump questions.
Old May 4, 2011 | 08:00 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
I purchased a GM high volume oil pump from summit for my 383 build and have decided i don't need high volume .Can I just replace the spring to lower the volume or does replacing the spring only affect the oil pressure?
Old May 4, 2011 | 08:19 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: High volume oil pump questions.
I think the volume comes from the size of the passages, not the spring. If you got it from Summit, they should swap it with no issues if you choose to go that route.
Old May 4, 2011 | 08:26 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Yes, the spring only controls the pressure. To change the volume, you need to swap the pump.
Old May 4, 2011 | 08:37 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Thanks for the fast replies guys,I think I'll just exchange it for different pump.
Old May 4, 2011 | 08:59 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Most builds do not require a HV pump. When using a HV pump you need a higher capacity pan. A friend of mine replaced his stock pump with a HV pump and starved the engine of oil at higher rpm's with a standard volume pan.
Old May 4, 2011 | 09:52 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
ive said it before and ill say it again, a HV pump wont starve your motor...
i have a big block pump with a 5 qt oil pan and havent run into problems over the several thousand miles ive used that set up.
pick thru this thread...
https://www.thirdgen.org/forums/tech...ml#post4890948
towards the bottom Aperion explains how and why it wont...
notice the citation of November 2009 Car Craft. thumb thru that issue or better yet, view it online
http://www.carcraft.com/techarticles...NTERSTITIAL_15
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
BBSDesigns
Aug 11, 2015 07:39 PM
