"A" Pillar Molding (trim) Weatherstrip
Old May 22, 2011 | 02:36 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Pulled both "A" pillars plastic trim pieces off my GTA today to replace the door weatherstripping and noticed a narrow weatherstrip attached to both "A" pillars. Does anyone know where one can find these weatherstrips because mine are dry rotted completely. Also looking for used plastic "A" pillars as well with the clips intact for the plastic screws as mine are broke on both sides....
Old May 24, 2011 | 01:08 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: "A" Pillar Molding (trim) Weatherstrip
As far as I know they do not produce them anymore. there is a thread on here somewhere where a guy has replaced them with something from lowes. might try that rute or search the local junk yards.
Old May 28, 2011 | 08:40 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
Are you talking about this:
If so, check out this thread: https://www.thirdgen.org/forums/body...-question.html
Old May 29, 2011 | 09:49 AM
djmarch's Avatar
Engine: 5.7 ltr.
Yes...That's the part
Old May 29, 2011 | 03:29 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I'm actually in the process of replacing that foam right now.
I bought this from Autozone for $13
This is how it looks installed:
You have to cut the replacement foam so it's not too wide. Also, don't remove the old foam, you'll need it as backing for the new foam to attach to.
Old May 29, 2011 | 03:50 PM
djmarch's Avatar
Engine: 5.7 ltr.
Hey man...That looks really good...Can't tell from the pic, but what's the p/n on the bag ? Was this located on the shelf or did you have to specify it at the counter ?
Old May 29, 2011 | 05:02 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Metro SUPERSoft Camper Top Weather-Strip
Part Number: MW11425
It was located on the bottom shelf in one of the isles. You get 25ft of weather strip. You only need about 8ft per side.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
