Iroc z Idle problems *VIDEO*
Old May 23, 2011 | 10:42 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
Hey everybody,
I just bought this iroc recently for very cheap, and it didnt run when i bought it.
So ive replaced the ignition control module and distributor pickup and after setting the timing, it fired right up.
HERES MY ISSUE. it idles very poorly when cold.
Here is a video describing/showing my problem.
ANYHELP WOULD BE APPRECIATED VERY MUCH...
http://www.youtube.com/watch?v=6h4CUG8rYMo
Im thinking of replacing my iac valve as it seems shot. let me know what you all think.!
Old May 24, 2011 | 12:40 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: Iroc z Idle problems *VIDEO*
seems like you have a cam and that's causing what you think is a rough idle.
Old May 24, 2011 | 08:29 PM
zz's z28's Avatar
Car: 1987 Iroc Z
The issue im having with it is not so much the lopeyness of the idle.
Its how drastically it fluctuates. On a cold start, the first 30 seconds, holding the gas is required just to keep it alive.
Im really leaning towards a bad idle air control valve.
Are there any other sensors, or problems that can cause this.
i know for sure i have an exhaust leak right on the drivers side manifold collector.
THanks for the reply!
Old May 24, 2011 | 08:47 PM
john36mc's Avatar
try to clean the iac it could be gummed up. I also have the same problem but i think i need to set my timming
Old May 24, 2011 | 08:55 PM
zz's z28's Avatar
Car: 1987 Iroc Z
i bought a throttle body off of my buddy for 20 bucks, and that has the iac valve included.
just finished polishing and cleaning everything, including the iac.
hopefully this fixes it,
also, i wouldn't be surprised if my timing was off as well. i could barely see the timing mark last time.
Any other reasons my idle could be fluctuating? besides the previous owner having possibly put in an aftermarket cam...?
Old May 24, 2011 | 09:07 PM
john36mc's Avatar
vac. leak? egr open?pvc valve stuck.
Old May 24, 2011 | 09:41 PM
zz's z28's Avatar
Car: 1987 Iroc Z
thanks alot!
Now im gonna go make a checklist!
Old May 24, 2011 | 11:12 PM
theNMBR27's Avatar
Check your timing and make sure it's at 6 degrees btdc before anything. And give it a good seafoam.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 11, 2015 03:17 PM
