fuel pressure problems
Old May 25, 2011 | 05:51 PM
nova1396's Avatar
i have a fuel pressure guage on the shrader valve and when i turn the key on it goes to 45 psi then the fuel pump kicks off the pressure goes to 0 and you can hear the gas return to the fuel cell. is this a regulator problem?
this is a 283 i built on an engine test stand with and 86 tpi maf setup and painless wiring harness. please any help would be great.
Old May 25, 2011 | 06:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pressure problems
Most likely a regulator problem, yes.
Old May 27, 2011 | 02:19 PM
nova1396's Avatar
i replaced the regulator and it sill does it.
the main problem i am having is 1 and 8 wont fire. i have checked everything got spark, fuel and compression. new distributer new injectors checked valve train while engine was running and all valves are going up and down, its like its not getting the fuel. but niod light works and injectors work on all other cylinders.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
