any advice on timing chain set ??
im putting a cam in my 86 305 iroc and was wondering if you guys had any recommendations on a timing chain set ... its a flat tappet cam and would like to use factory cover ... i dont know if a double roller will fit with the stock cover .. ill be getting it from summit so if you have a part # that would be cool ..
Transmission: 4L80E/4L80E
Re: any advice on timing chain set ??
A double roller set fits fine behind a stock front cover.
Guest
Posts: n/a
Back when I put a 350 in my '86 IROC-Z, I spent a lot extra on a Manley double roller. A couple of years later, taking the engine apart, the chain had no slop in it. That really surprised me. Cloyes is supposed to be the first name in timing sets, but I found an excellent alternative.
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Defenatly replace the set. A double roller is what I used
any of you guys have a part# i can get .. every chain set i click on summits site it says its for a roller cam and will not fit behind stock front cover ..
Guest
Posts: n/a
This is what I used, IIRC: http://www.summitracing.com/parts/MAN-73111/
there are cheaper options, but I feel this is worth it.
