Valve noise?
Old May 30, 2011 | 07:58 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Valve noise?
Would a "chattering sound" coming from under a valve cover mean loose rocker arms?
Sorry if that's a dumb question, but I've never ran into this before personally. I haven't adjusted the valve lash sence I assembled the engine. (I used the method in the Haynes Manuel)
Old May 31, 2011 | 12:38 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Valve noise?
very possible. It would not hurt to pull the covers off and check.
Old Jun 1, 2011 | 02:38 AM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Re: Valve noise?
Exactly what it sounds like. If you notice one is loose, go ahead and adjust it back to spec. most importantly, if this happened over time, make sure to replace the nut! otherwise youll be pulling the valve covers back off in a week lol
Old Jun 1, 2011 | 02:40 AM
oH HorizoN's Avatar
Car: 1989 IROC-Z Camaro 'Vert.
Engine: 350, ZZ4 motor
Transmission: TH-700R4
Axle/Gears: 2.73 ... for now.
Re: Valve noise?
Hopefully it's just the rocker, and not a lifter!
Old Jun 1, 2011 | 03:10 AM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
Re: Valve noise?
If its been doing it all along then you may have had them too tight from when you first assembled the engine.
A friend of mine had assembled his engine and ran it for a whole year before he decided to have me adjust his rock solid lifters that ticked like crazy. They adjusted just fine and no ticking afterwards.
gta892000
Aug 11, 2019 11:16 AM
drptop70ss
Oct 4, 2015 09:44 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Randomtask2
Sep 7, 2015 05:06 PM
