Oil pressure 10 psi at warm idle is this a problem?
Old Jun 4, 2011 | 05:00 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
I have a 91 firebird with a 305 TBI and 151,000 miles. At warm idle the oil pressure is reading at, I think, 10psi if I'm reading the gauge right. There are no knocks or taps coming from the engine and it runs pretty smooth. Is this pressure a problem?
Old Jun 4, 2011 | 06:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil pressure 10 psi at warm idle is this a problem?
Assuming the gauge is reading right, which it almost certainly isn't, it's not that much of a problem.
Old Jun 4, 2011 | 10:02 PM
macmatt's Avatar
Engine: 305 TBI
should I hook up a mechanical gauge and see what it says?
Old Jun 7, 2011 | 10:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you want to.
Old Jun 8, 2011 | 08:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Might try a new sender for the guage - it's located just above oil filter, about $30.
Old Jun 8, 2011 | 10:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A mechanical gauge will confirm if you have a bad sender or dash gauge.
What does the pressure increase to when you rev it up?
I fixed a truck a couple of years ago that had bad oil pressure when the engine was warmed up. 15 psi when reved up and dropped to 2-3 at an idle. No engine noises at all. Ended up being bad cam bearings.
Old Jun 9, 2011 | 12:14 AM
macmatt's Avatar
Engine: 305 TBI
It's got a new sender on it. I think I was reading the gauge wrong. When cold it sits consistently at 30psi. When warm it Idles around 15psi (At least I think that's 15, it's the mark directly in the middle between 0 & 30). When I drive it it's usually between 30 & 35.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
wayshegoes
Aug 17, 2015 12:00 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
