Intake manifold for 305 fit on 350?
Old Jun 9, 2011 | 08:48 PM
Willsmith305's Avatar
Car: 1989 Camaro RS
Engine: 305 Carb
Transmission: 700R4 Mild shift kit.
I'm not sure if this is a stupid question or not but what the hell I'll ask it anyways. I ran the casting numbers on the intake manifold and it showed for a 305? Should this be enough evidence to say its a 305 or should I still get the casting number off the block to see if its a 350?
Old Jun 9, 2011 | 08:53 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Intake manifold for 305 fit on 350?
The manifold could bolt directly onto either a 305 or a 350. Only way to be sure is check the casting number on the block.
Old Jun 9, 2011 | 08:55 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
check the block, if you reall wanna make sure tear it apart and measure the bore. but the casting number on the block will do you fine, if you know of a place that you can get info on the number
Old Jun 9, 2011 | 09:00 PM
Car: 1989 Camaro RS
Engine: 305 Carb
Yea I'm gonna have to quit being a panzy and just yank the distributor out. Only way to get to it. I think I'm gonna yank the whole engine out. It needs some work done haha
Old Jun 9, 2011 | 09:10 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i wouldnt yank it out if you just had to replace a rod or something small, but if your planning on rebuilding or swapping the whole engine then yanking it out would be ideal
Old Jun 9, 2011 | 09:17 PM
Car: 1989 Camaro RS
Engine: 305 Carb
Replacing the intake manifold and carb. I don't need to yank it for that but they really put the engine in and made it look really really bad. I can't stand it to tell you the truth haha
Old Jun 9, 2011 | 09:23 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
the prior owner swapped in a diff engine? and he did a bad job? have fun with that, i hope they didnt hack off wires for you to figure out and everything. dealing with other peoples prior messes just isnt close to being wonderful
Old Jun 9, 2011 | 09:40 PM
Car: 1989 Camaro RS
Engine: 305 Carb
Prior owner swapped. They did a bad half *** job of putting it in. I just wanna clean it up. It runs good and strong, just needs some TLC
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
