Possible Bad Water Pump Bearings?
Old Jun 11, 2011 | 09:47 AM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Hello, Im gettig this loud scraping sort of sound when the engine is idling and is very noticible, I was told yesterday that it sounds like the water pump. I did a quick look online to see if I could diagnose it for sure before I went out and bought a new water pump and I learned that if I grab the fan on the top and bottom and try to wiggle it (similar to the way you grab a wheel to check for play in a wheel bearing) then if you feel play in the fan it could be the bearings in the pump. I tried this and found it hard to get a grip on the fan but from what I could conclude there wasnt any play in the fan.
Just wondering what you guys think.
Old Jun 11, 2011 | 12:01 PM
Re: Possible Bad Water Pump Bearings?
Loosen the belt and see if it quits.
However, since you have a HO, your fan is electric; messing with that won't tell you anything at all about your WP.
Old Jun 11, 2011 | 12:25 PM
I see, think the belts could be causing the problem? the V-Belt for the water pump/crank/power steering looks heavily cracked up.
Old Jun 11, 2011 | 12:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Likely. One way or another the belt should be replaced.
JamesC
Old Jun 11, 2011 | 04:22 PM
The Serp belt wasnt bad but I just went ahead and went down to my local parts store and picked up both belts for $44 CAD and now the sound magically disapeared
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
xxx3man`
Sep 23, 2015 10:37 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
