pressure washing engine big mistake
Old Jun 11, 2011 | 07:11 PM
soxbaseball's Avatar
I had a radiator hose bust, so I a bright idea lets pressure wash the engine. So now my 87 trans am's 305 tpi will run for about 15-20 minutes then cut off like someone is just turning the key off. Any ideas as to what would be causing this?
Old Jun 11, 2011 | 08:25 PM
the_am_man's Avatar
Car: 82' T/A
Engine: LG4
Transmission: THM200c
Re: pressure washing engine big mistake
Well you have your first clue atleast, after the car warms up the problem arises. Although it should be warmed up in 5-10 minutes atleast
Old Jun 11, 2011 | 08:29 PM
RyanEricW's Avatar
Did you let the car dry for a day or two? Try running the car without the air cleaner/filter on.
Old Jun 12, 2011 | 01:41 PM
oif0709's Avatar
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
lol yes that was a problem, these old cars you just cant do that to unless everything properly sealed off. I would check the air cleaner as stated then go through and look for where water might be sitting. does it spit or sputter when it starts to die?
Old Jun 12, 2011 | 05:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
codes? sounds like it runs until it hits closed loop..
Old Jun 12, 2011 | 05:11 PM
oif0709's Avatar
do you have any codes that come up?
Old Jun 13, 2011 | 08:37 PM
I dont have any signs. It doesnt spit and sputter it just shuts off almost like i turned the key off. I had read somewhere that there is a weather block near the battery with a fuse in it, could this be causing my problem?
Old Jun 13, 2011 | 08:51 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
unlikely. if that fuse was wet or blown, your car wouldn't run at all.
Old Jun 13, 2011 | 10:50 PM
RyanEricW's Avatar
Not sure what a "weather block" is, but if I'm guessing correctly that is a power distribution block, afaik on my 92 it gives power to my cooling fan, which the relay controls the ground, power to the starter, and (maybe goes to alternator).
My question is.... does the car have ANY power at all (headlights,instrument cluster, door chime) once the engine dies, or is it a total system shutoff?
Old Jun 14, 2011 | 07:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Remove the distributor cap and dry it and the distributor with a hair dryer.
RBob.
Old Jun 14, 2011 | 08:06 AM
Its just the engine everything else stays on. Ill pull the cap and rotor off and check but if it was that wouldn't the car spit and sputter?
Old Jun 14, 2011 | 10:31 AM
What do you mean closed loop?
R3500
Aug 17, 2015 12:16 PM
kyleb24
Aug 15, 2015 08:24 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
