Temp gauge not working after new plugs
Old Jun 19, 2011 | 03:39 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
A few weeks ago me and my neighbor changed all the plugs and wires on my car. Car now runs fine but the gauge didnt work after the first start up. He believes he might have knocked something off but I dont know where to check at to see if that is true. It is pretty important because my fans are hooked up to a switch and it makes it hard to tell when I need to turn it on (I have just been turning it on after 10 min). Even still it irks me that it doesn't work. Where would I look to see if the connection is still there? I have the stock 350 TPI.
Old Jun 19, 2011 | 03:45 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Temp gauge not working after new plugs
Driver's side cylinder head. Between #1 and #3 plugs. Single green wire connects to the sender.
Old Jun 19, 2011 | 03:50 AM
Thanks, I'll have to check that out tomorrow and let you know what I find (it's 4 am and I am tired and dont have a garage or jack available at this hour). Or could I see it without the jack?
Old Jun 19, 2011 | 03:51 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
You can see it from the top. Just look at #1 and #3 plugs.
Old Jun 19, 2011 | 03:53 AM
Cool that SHOULD make it really easy then. lol
Old Jun 19, 2011 | 02:36 PM
I found the green wire but I can't find where the plug in is at and Chilton isn't helping me any either. Anyone have a picture of where it plugs in at?
Old Jun 19, 2011 | 03:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I don't have a picture but the sender is directly between the two spark plugs. It has a round button that the connector slips over. If it's an aftermarket replacement, it will have a blade terminal.
Old Jun 19, 2011 | 07:18 PM
My sender has the round end and the wire has the connector that is like the one used for the speakers. Is that correct or is something wrong? Like the end of the sender feels like a spark plug.
Old Jun 19, 2011 | 07:21 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah, that's right. the connector slips over the "nail head' at the tip of the sender.
Old Jun 19, 2011 | 07:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the connector connects perpendicular to the end of the sender, it doesnt push straight on like the typical connections for speakers
Old Jun 19, 2011 | 10:21 PM
Thanks guys I got it all put together and it works great now! Even though it still shows that my car overheats a bit.
Old Jun 24, 2011 | 11:58 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
My temp gause has recently begun reading randomly. One ignition cycle it will read high on the scale, next time it will run pegged at the top or maybe the bottom. Fairly sure it's an issue with the cluster itself. My engine never runs hotter that 185.
Old Aug 10, 2011 | 08:48 PM
Iroc-Z Tone's Avatar
Car: 1985 Camaro Iroc-Z
Engine: 350 5.7 TPI
THANKS ALOT! i had the same problem, my temp sender & the plug on the green wire did not look like they went together. I just connected it then BAM! My temperature gauge works again!
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
