A wierd noise coming from engine after start up.
Old Jun 20, 2011 | 02:00 PM
87Proud's Avatar
Car: 87 Camaro
Engine: 305 5.0L V8 4BBL Carb.
Hey all I was hoping i could get some help on this. A few times here and there, not on every start up just a few and it only lasts for a min, but I'll get a noise almost like two plastic cups hitting each other, sounded like it was coming from the rear of the engine but then when i moved to try and hear it was back at the front and i didn't have a tube with me to filter it down, but my ac and smog pump are disconnected, and my alt and water pump are new so i guess its could be my power steering pump? Maybe the pulley is just moving back and forth? Any help will be appreciated.
Old Jun 20, 2011 | 07:20 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: A wierd noise coming from engine after start up.
My power steering pump makes a cheesy noise something like what you are describing. It quits like yours also.
Old Jun 20, 2011 | 09:21 PM
87Proud's Avatar
Car: 87 Camaro
Well I gotta change my power steering pump's main hose so ill look at it when i'm in there and play with it for a little.
Old Jun 20, 2011 | 09:29 PM
I have had the same noise for year, and it has never worsened, so I have ignored it till you mentioned it. I still don't worry about it.
theshackle
Sep 17, 2020 08:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
