Oil weight & Brand
Car: '86 Camaro Z28
Engine: 350 Tpi
Transmission: TH700R4
Axle/Gears: Factory
Oil weight & Brand
What brand and what weight oil do you guys use also what motor are you running?
I had some tell me to run 10w-40 in the 305 I had.
I am going to be running a 350 just curious as to what others use.
Re: Oil weight & Brand
how you like your burger cooked and with which condiments and sides do you like too?
be prepared for hundreds of opinions because that's all it is. The oil topic has been beaten to death but welcome to the fun world of cars.
But here I'll answer your direct question
FL resident it goes down to 30's in the winter and low 90's in the summer
Stang- what ever is on sale at ADV auto 5w30
3rd gen- what ever is on sale at adv auto 5 w 30
4th gen- what ever is on sale at adv auto 5 w 30
mazda- what ever is on sale at adv auto 5 w 30
honda- what ever is on sale at adv auto 5 w 30
nissan- what ever is on sale at adv auto 5 w 30
mercruiser 5.7L- what ever is on sale at adv auto 5 w 30
lawnmower- walmart 5 w 30
weed whacker- 2 stroke weedeater or poulin brand
lawn edger- same as weed whacker
pressure washer- walmart 5 w 30
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I've been using Mobil 1 Fully Synthetic 15/50 since 1993 with no issues. But a lot of engines have their own "personalities" and do run better on other types of oil synthetic or not.
Car: 1987 Camaro LT
Try each brand on two oil changes. See if there are any noticeable differences. How often do you change your oil regardless of it being synthetic or not?
Car: '86 Camaro Z28
Engine: 350 Tpi
Axle/Gears: Factory
Usually 3 months 3000 miles sometimes a little longer maybe a hundred miles or so usually pretty good about keeping on top of it
Car: 1987 Camaro LT
Well since you are planing on using the same weights and both synthetics, you should be fine on trying both brands at two different oil changes.
Car: 86 Trans Am
Axle/Gears: Aussie 9 Bolt with 3.0 Gears
I use what the owners manual says, regardless of mileage.
1986 Pontiac Trans Am 5w-30 (100k) Castrol, Valvoline, Penzoil
1972 Pontiac Ventura 5w-30 (20k on a rebuild) Castrol, Valvoline, Penzoil
2004 Pontiac GTO 5w-30 (127k) Castrol, Valvoline, Penzoil
2005 Chevy Cobalt SS SC 5w-30 Synthetic as required (74k) Mobil 1
2005 Chevy Trailblazer 5w-30 (60k) Castrol, Valvoline, Penzoil
Transmission: 4L80E/4L80E
Ah, the monthly "oil brand/type/weight flame war thread".
Barely got it in before the end of the month.
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
